Can anyone help i have a Smeg A42 double oven when you use the lower/larger oven it works fine until you turn the oven off, and immediately trips the fuse in the main house fuse box.. I have found that if i turn the oven down to so you just have the kight on and leave it it for 10to 15 mins and then switch it off it turns off with out tripping breaker, does anyone have any idea's as SMEG technical are about as helpful as a chocolate fireguard.
SOURCE: smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
SOURCE: i have a smeg range, gas burners electric ovens.
it sounds like the main oven is in timer mode on the timer please read instructions
to rectify
SOURCE: Smeg SUK91MFX5 oven overheating
REMOVE BACK PANEL TURN OFF POWER CHECK WIRING TO & FROM CORD BLOCK
