Question about Logitech Trackman Marble FX Trackball
Logitech trackman marble fx model T-CJ12
I need to order the little bearings that r inside the mouse.
R they available?
Thanks
Posted by rebelwarrior on
Swilin Sampson
    President:
  • 2,712 Answers
Hello rebelwarrior,
Unfortunately, Logitech do not sell these components separately..The only components that they sell fro mice are replacement mice feet. They will replace the entire unit if it is still under warranty and is unopened/tampered with. You contact their customer via email HERE. They usually respond within a day or two max. (I know, because I was on the support desk for a while ;))
If you wish to call them, the number is:
+1 646-454-3200
Monday - Friday: 6am - 6pm PST
Saturday - Sunday: 7am - 5pm PST
However, I think you may be able to find suitable replacement parts at your local computer store or by doing a Google search online...Hope that helps...
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
"Discover How to Achieve Your WILDEST DREAMS"...Free Download
FREE SOFTWARE GIVEAWAY
Windows Utilities - Software Street
Posted on Apr 23, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Where can I find rear bearings for this unidentified bicycle?
A little more information would be very helpful.
Most rear hubs are Shimano.
The bearings are available in any bicycle shop.
S-Ram is rarer, and may have to be ordered over the INTERNET.
The Chinese brands are almost hopeless.
Look for a part number stamped on the hub, and use Google.
Jul 27, 2015 | Cycling
LLogitech wireless mouse LX5
ok.. got your email.. kindly wait and i send it right there..
thanks
Apr 16, 2008 | Logitech LX5 Cordless Optical Mouse
I accidentally fumbled and dumped an entire cup of coffee on my Logitech marble mouse! I extracted the ball, dried everything off inside and out, and even cleaned the little optical window inside the...
Turn it belly side up. If there is a retaining ring turnit counter-clockwise to remove it Pop out the ball.
There are three little bearings about the and shape ofa BB Take a Q tip and dry and or remove any debris on the BBs There should also be a little black rectangle. This is thewindow that the sensor looks at the ball through, Clean/dry it with Q-tip. Put it back together and try again.
Mar 18, 2011 | Logitech Marble Mouse USB (LOM9043600403)
The mouse does not work at all. I put in new batteries and still does not work. I had problems with my computer and since that is fixed the mouse does not work.
Hello, Allow me to try to figure this out here.
Your saying batteries and mouse so may i assume this is a wireless mouse for a moment?
Okay once you replace the batteries in the mouse you need to unplug the little transmitter from the computer, Reboot, Then plug it back in.
This would allow it to re-sync being that its infra red or otherwise.
So try that. Take out the little transmitter thob, reboot, plug it back in, the mouse should be working again.
1.Check the batteries are they in backwards?
2.Check the battery connectors inside,
Now if this is a IMAC or something like that quickly let me know!
Thanks for using fixya.com I hope this was very helpful.
Regards
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 27, 2011 | Computers & Internet
Motor speed is erratic. Now it makes grinding noises
There is a speed governor on the motor end of the armature (back end of the motor) that may
need replacing. It's one of the few parts still available. on eBay, or mendingshed.com
The grinding could either be the gears in the beater end of the mixer, or the motor bearing on
the back end of the motor.
The gears are available as they are the same as for newer mixers like the K5SS.
The motor end bearing is not available, but I was able to take the bearing out of the motor
bearing plate from a K5SS which is still available, again on eBay or mending shed, and put
it in the motor bearing plate for the K5A. Then you need to soak the felt ring inside the housing
on the back end of the bearing in oil, preferably synthetic like Mobil 1. Also helps to smear
a little moly grease (not out of a tube, not enuf moly content - get some Honda Moly 60, small
tube for $10 at any Honda store) on the shaft when you have it apart.
Jan 21, 2011 | KitchenAid Classic Stand Mixer
The mouse has lost its air feature. Still works from a desk as an optical mouse. Produces a high pitched sound .
Sorry my reply is five years after the question but I really hope this reply can help anyone out. I have a gyration GYR3101US Media center remote.
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-0.jpg I love this remote/air mouse but after I dropped it about two months back anytime I would try to use the air mouse, it would emit a loud high pitch sound and put the cursor near the time clock unable to move it. Tonight I took it apart. this is what I found. There is one screw behind the batteries, then you have to pry it apart with a flat head. once inside find the gyration sensor
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-4.jpg CAREFULLY pry apart the sensor with a little flathead, there is a metal plate on the bottom of the sensor so DO NOT pry from the circuit board up that will break the sensor off. Put the screw driver between the metal plate and the outer casing you should see a little crack. also i cut most of that red tape off with a razor blade before prying.
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-7.jpg The red arrow is pointing at the part inside the sensor that had come lose from the drop and was moving about freely inside. I'm guessing it's a weight or magnet. After carefully and gently snapping it back in place, put your mouse back together enough to test it. at first it still had problems but i double clicked the mouse movement button and set it on a flat surface so it could calibrate itself. SUCCESS. I hope this helps my gyration is working fine now. contact me if needed john4628 AT gmail. (There are no fans or bearings in this mouse or any gyration mouse)
Feb 05, 2010 | Gyration GO 2.4 Air Mouse/Compact Keyboard
How do i clean a microsoft 5000 laser mouse?
You can clean your laser mouse using an alchohol. Just pour a little achohol in a cotton and wipe it all around the mouse. If you want also clean the inside of the mouse then you must a screw driver to open it. Once open, you need a brush and brush the mouse board inside. You can also use a blower to get rid of the dust inside. Hope this could help. Please don't forget to rate me..:-) Thanks..
Nov 05, 2009 | Microsoft Wireless Laser Mouse 5000
Bad computer connection for wireless mouse
Logitech does provide the replacement part for your USB mini-receiver, check the following website (availability 2009Oct23): Click Here
YBC (/\)
Jan 26, 2009 | Logitech Cordless Desktop MX3200 Laser...
My Wacom mouse is driving me insane!!!
I think I figured out this problem. It's more of a wearing issue with the constant use of the button. Basically the plastic tab on the internal underside on the mouse is wearing down from continual use. I added a piece of custom cut card stock under the front of the mouse circuit board. This raised it up just a little to compensate for the wear on the button.
Nov 14, 2008 | Wacom ZC100 Mouse
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Logitech Trackman Marble FX Trackball Logo
533 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
