Question about Kodak EasyShare C663 Digital Camera
I have a kodak easyshare c663. Powers up but turns off right away
I have a kodak easyshare c663. It was working fine but then I dropped my purse with the camera in it and now it's not working. When I go to power on, the "Kodak easyshare" display appears for a second and the little sound happens but then the display disappears and the blue light by the selector dial and the green light by the viewfinder flashes then it all shuts off. I've changed the batteries but still not the solution. Any suggestions??
  • Kodak Master
  • 6,217 Answers
Yes. It's broken.
Posted on Jun 30, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Kodak v550 digital camera
THANKS!! I thought my camera was gone for! This worked for me!
Christie
Posted on Sep 01, 2008
Anonymous
SOURCE: Kodak Easyshare camera turns on and off
Yes you are. My wife denied that she dropped in the sand but I found a list of photos that she wanted to print on a post-it paper in the cover and it had sand all over the sticky part. Used the pressure air spray to clean the rings and it is back to life. Well It worked but there was some problem during zoom in&out, so I spray the rings while zooming and out and that cleaned it. I hope I don't have to open it to clean the mechanism. Thank you.
Posted on Jun 08, 2009
Anonymous
  • 8 Answers
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Posted on Aug 15, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: My Kodak EASYSHARE M1063 camera won't turn on
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 13, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: kodak easyshare c643 - batteries are fresh, but it
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Dec 20, 2009
Testimonial: "Thanks for the help!"
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
Tip
Kodak EasyShare C663 digital camera Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Kodak's official website.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
on Mar 08, 2010 | Kodak EasyShare C663 Digital Camera
4 gb sd card not formatting
The C663 works with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to go with SD cards, 2GB and smaller.
Nov 25, 2010 | Kodak EasyShare C663 Digital Camera
Can C663 work with a 4 GB SD card?
No. The C663 uses SD cards 2GB and smaller, not SDHC cards 4GB and larger.
Aug 30, 2010 | Kodak EasyShare C663 Digital Camera
Camera works fine other than the joystick. I changed the battery to see if the battery was low and now I can't get past the time/date setting because the joystick won't respond. Any ideas?
It means that the joysctick of camera is defective., Please call Precision camera and binocular repair to send the camera for service Its for US support 1 800 665 6515 or you may call kodak 1 800 235 6325 for an alternative options and solutions., Gudluck!
Oct 21, 2009 | Kodak EasyShare C663 Digital Camera
We have a C663 and C360 Kodaks. Both doing same
This problem is frequently the result of corroded battery contacts inside the camera. Remove the batteries and wipe the inside camera contacts with a soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Make sure there's no cleaning residue left inside the camera, then clean the battery contacts and reinstall the batteries. If this doesn't solve the problem you may have something more serious wrong with camera and I recommend checking the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format do diagnose problems and attempt to find a solution.
Jun 07, 2009 | Kodak EasyShare C330 Digital Camera
Kodak c663 camera not working !
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
Apr 24, 2009 | Kodak EasyShare C663 Digital Camera
Lense stuck
You have a cracked or stripped gear. If you ever took it to the beach it likely got sand inside. Even a little. You should try blowing out the gaps with compressed air from a can of air duster. If that doesnt work, you need it repaired
Feb 02, 2018 | Kodak EasyShare C663 Digital Camera
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
Kodak Easy Share 663 Camera Help
Get onto the Kodak Tech Support site If it is in warranty they will fix/replace it If it is out of warranty there may be a reasonable swap out offer.
Jul 16, 2007 | Kodak EasyShare C663 Digital Camera
Kodak EasyShare C663 Digital Camera Logo
208 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
