Gateway MT3418 Notebook Logo
Posted on Jun 08, 2009
Monitor is black, nothing
I have a Gateway MT3418 laptop, The lights and unit is on and running but nothing on the screen. We hooked an exteranl monitor to the unit and still nothing comes on. But the unit is running. any help would be appreciated.
Hp g61 notebook pc bios blink error code 2 black screen led lights above num lock key and led lights to left of caps lock key flash 2 blinks.no monitor when hooked up to an external monitor.cd disc drive...
If screen and external monitor do not work then the issue lies with the video section of your laptop. The video chip is soldered onto mo bo and there is noway you can replace it if bad. Kiss your laptop sayonara, salvage the hard rive and memory and get yourself a new laptop that works. And avoid HP - their customer service is non existent after warranty runs out. They refer you to a forum or tell you to get another unit - an HP of course!
My Gateway mt3418 has dead video card what is solution?
Typically, installing a video card will have to be done by the manufacturer. Finding this type of part, especially from Gateway, will be very difficult. Installing the part will be even harder.
Getting this fixed may be more than the actual laptop is worth.
Contact Gateway for pricing.
Gateway MD2614u, froze at start up when restart was attempted nothing appeared but a black screen. It will not restart. I have tried the battery/power reset, vacuum any dust and hooked up to another...
Actually this is a hard drive fault most likely, or a faulty had drive. If you don't have a recovery disk you are going to have to start the machine and try to do a recovery to boot repair. You can usually access this with F10 or F12, not really sure on a gateway.
Black screen upon boot
try to remove the battery and unplug the power adapter. press power button for 30 sec. then connect power adapter. check if the pc able to turn on
Screen Black on Gateway
yes and no, i never have to replace the motherboard on a computer but i say you probably can upgrade it.
1helpful
Gateway Computer with Black Screen
hit the function key hold it down and hit the keyboard key with the monitor "icon" on it. It's usually F5 key.
Hope this helps.
I can tell the power is on but I get nothing on the screen.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
My Gateway 450ROG laptop/notebook has problems on start-up. Whenever you turn it on, the fan starts up, then the three lights blink and there is a tone heard immediately after that. But there is nothing...
Try hooking the Laptop to an external monitor like from your desktop pc,,you can see the connection on the back of the laptop,,When you do this, and you can see Windows on the Desktop monitor,,then this would indicate that your Back light on your Laptop screen may have burnt out .
2answers
All the lights of my gateway MT3418 are on, but screen is black
Can you see a background image when get really close to the screen?
Cheers
Gateway 450ROG screen problem
This could be the inverter, or screen cable. Try replacing the cable first.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
