Question about GE 24GP653 24" TV
Resistor value I am working on a GE 24GP653 TV and want to know the value of resistor R404 Thank you
Posted by Cecil Grannum on
Anonymous
The value of r404 is 10 ohm 1/8 watt
Posted on Dec 18, 2008
Anonymous
1O OHMS
Posted on Apr 22, 2008
LG crt tv 21fs4rge-TS resistor R407 burnt i don't know the value
A burned out resistor means too much power has flowed and burned it out.
you need a schematic to find the resistor value but also what other parts have blown as I can guarantee just replacing the resistor would just mean another burned out resistor.
Jun 16, 2018 | LG Televison & Video
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
My GE timer, model 15132 has stopped working. I can see that resistor R2 on the circuit board has fried (it's black). Anyone know the value of this resistor?
Usually if you look close, several parts have burn or blackened area at point of solder.
This indicates that multiple parts are affected... replace timer.
Otherwise, there is no schematic for these types of digital timers that shows the value of parts.
Following resources have images of similar problem, and similar timers.
http://waterheatertimer.org/Timer-caught-fire.html#resistor
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/How-to-wire-GM40-timer.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 10, 2015 | GE Hardware & Accessories
Value resistor 719 of chasis serial : qpwbf9254mezz,tv sharp 27" model: 27j-s100 or diagram. thank you for his help
I looked at the same chassis I have and the resistor has color bands green blue silver gold wich is a .56 ohm 5% 1/2 watt resistor
Dec 03, 2010 | Sharp 27J-S100 TV
I have a Toshiba projection T.V, model number 43J7DM.It is dead
247 is .050 watt15K ohm
404 is 0,25Watt 1K ohm
420 is 0.5 watt 10K ohm
513 is 0.25watt 100 ohm
However if you dont understand them dont play around with them you may end up doing more damage than what you have now. If resistors blow then some other fault has caused excess power to fuse them and that takes knowledge of how to measure the current at each step. Some of these resistors are related to the power board. Getting circuit diagrams from toshiba is difficult Quite often there is a diagram inside the chassis of each model.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Toshiba 55H70 55" Rear Projection...
I am replacing the 10M resistor with a lower value but can't find a source. This is supposed to cure the brightness problem. Telectron was mentioned in one forum as having a kit comprised of 3 different...
If you cannot find a 10M ohm resistor you can connect lower value resistors in series so it totals to 10M (ie two 5M resistor in series equals 10M). The only thing you need to be careful is to make sure the wattage is the same or higher than the original resistor.
Jan 05, 2010 | Dell P1110 21" CRT Monitor
I have a resistor problem in sanyo ST-21G1
it's very difficult to give the exact value of that resistor.,but i can give some tips to find the value of the said resistor .( find how the resistor works, it is a dropping or fusable? if fusable used .47 or 1 ohm resistor if it is a dropping resistor you should make a trial and error .from 100k,10k or 1k.
Oct 29, 2008 | Televison & Video
Missing resistor
1.8 ohms at 2W
Dan
Sep 23, 2008 | Sharp 27H-S60 TV
Need value for part R14109
R14109=750ohms 5% 1/4w (Resistor(750r5%.25W/R14109/179317) There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it. If you need the manual, go to http://www.samswebsite.com/photofact/pf_search.asp and type in "F31317" into the search field, you will several listings. If you decide to replace it yourself, here's some more part numbers in case you need them. Model: RCA\F25422TX41 Symptom: Dead Necessary parts: Transistor(Q14401) Main Voltage regulator Q14101 Resistor R14109 open. Research indicated the flyback transformer most probably bad \\CTC203AC4\HOT/D2578(Q14101/242224)* Flyback(14536119A/T14401/244229)* Main reg(P9NBSO/Q14101/244223) \Reg(MPS8599/Q14102/147665) Resistor(750r5%.25W/R14109/179317) Reg(MPSA06/Q14103/232218) Hope this helps you. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | RCA F31317 31" TV
No sound, blue screen with blur of red, an green
the resistor overheated as a result of the diode or the capacitor went bad. Your gonna need to get a schematic diagram and find out what the part #s are as you cant just put in any type of diode capacitor or resistor. Also see what thay voltage source feeds and make sure nothing else is shorted.. Good Luck
May 19, 2006 | GE 24GP653 24" TV
GE 24GP653 24" TV Logo
77 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
