Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
Horizontal lines in sony Bravia 26"
The screen is 26". The lines are on the Bottom of the screen, full height of the screen and about 4" to 5" wide. The lines are grey and white color.
Posted by deanrayan on
Anonymous
  • 80 Answers
You need to replace IC8C01 and IC8C02 part# STK394-250. They are located on the main board (in the middle of the chassis) and are mounted on a large aluminum heat sink.
Posted on Jun 08, 2009
  • Anonymous Jun 08, 2009
    Incorrect post. I clicked on the wrong one. This is not the solution to your problem.
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Sony bravia internet tv has a pink horizontal band across the screen
If the line is Horizontal then you deffinantly have a cable issue, replace the cable and that should do it, if it continues the problem could be in the port itself, if using HDMI switch to VGA or composite to test this theory. please keep me posted.
Dec 27, 2013 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My Sony Bravia get a wide (about a foot) line up and down my screen. It goes off an on when it wants to. It picks up background colors and it stays like that for a while. What can I do?
I don't know what does your mean by "line up and down my screen", if the line goes up from the bottom to reach the top of screen then goes back down to the bottom cycles, that symptom I have never seen. But if the line goes off and on, very high probability is the panel defective (see the picture, the ICs inside the panel loose, shall cause the Vertical or horizontal dead pixel lines). It is the most serious issue on the flat panel TV. Because the manufactory sells the panels, price even excess the TV.
If you need more accurate diagnose, you can post a picture.
May 07, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
We have a sony Bravia and are watching a movie with some subtitles. The second line of the is off the bottom of the screen. How do I adjust?
On your television remote press the wide button, hopefully you have the television remote. You can press this wide button on the remote to select full and zoom, you should be able to find one of these options to fix the caption from being off the screen.
Dec 08, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
[email protected]
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Picture problems
I noticed that the "wide screen" button has 4 different options that should remedy this.  I think some of them are, "full scree, zoom, zoom wide, and normal".  hopefully this will help you out
Sep 23, 2007 | Sony HT-7100DH System
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
718 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
