Error code 5700 in mp520 canon
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
SOURCE: PRINTER FAULT
I,m not 100% sure on this. But A 5700 error on canon printers.
Would mean that the paper sensor has failed, or is not working.
Hope this Helps.
Regards Mike@Compurepair.
