Question about Indesit W 123 Front Load Washer
Indesit W123 - 8 Flashes Error Code
This fault is intermitent, but getting more regular.
When it goes into fault, it is within a couple of minutes of the cycle. The water drain out, the dial clicks around, and the on/off light flashes 8 times, pauses, flashes 8 times etc.
Any ideas appreciated.
Carlos
Posted by carlos_hippo on
  • carlos_hippo Nov 07, 2007
    Thanks, I'll give it a try.
Anonymous
    Scholar:
  • 97 Answers
Thats a problem with your heater, or the heater relay on the main pcb. best off replacing heater first as its the cheapest option.
hope this helps
kj
Posted on Nov 07, 2007
  • Anonymous Nov 07, 2007
    ^^REMEMBER POWER OFF BEFORE WORKING ON THE MACHINE :)
My indesit washing machine WI121 is taking several hours to complete a wash cycle on quick wash which should take 30 minutes
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes:
the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
Dado
Sep 14, 2015 | Indesit Washing Machines
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit W93, the light flashes but does not work
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Mar 29, 2009 | Indesit W 123 Front Load Washer
Indesit WIE127 Washing machine which flashes error code F08 when it goes to spin. Can this be fixed. What do I need to do to mend it?
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Jul 30, 2008 | Indesit Washing Machines
F-02 fault code on indesit we16 washing machine
According to info on a similar site to this, it means motor jammed/tacho faulty or detatched
Mar 23, 2008 | Washing Machines
Help
al indesit washer have a reset pattern
switch of with on/off button
turn selector to a large 'off dot' position
wait a couple of mins then switch back on
wait 2 mins
then switch off again and turn selector to a cycle start position
wait 2 mins turn back on and let it run the FULL cycle do not mess it about.
Sometimes it takes 2 or3 attempts so be patient
If there is a fault it will appear again within the cycle and give you an error code eg E7/E1 etc note this and call a repair man he will track it from this code.
Jan 26, 2008 | Indesit W 123 Front Load Washer
Washing machine just keeps spinning
wait 2 mins
Jan 22, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
888 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
Marvin
Marvin
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
