Contact [email protected] for billing support.
Turn it off and let it sit idle for about an hour. This should cure an
overheating problem
For no power and green light and red light go on, the problem is with power switch- top of unit.
After remove all screws, you need
LONG-LONG screwdriver and one short screwdriver with out handler, because few
screws almost imposable to remove. you make few holes on bottom of unit to
remove 4 screws.
you have two ways to fix switch problem-
1. replace it, if you can find new switch.
2.
solder two wire to switch and make a hole on top of unit. when you need to power
unit, turn back switch on and touch two wire as switch.
I no longer need your help. I discovered the paper bin was not completely shut. I didn't think of this since it had overheated and I was afraid I had ruined the machine. Please cancel my request for help. It is nice to know there is a great backup. The first response was a bit overload. He assumed I had already double checked everything.
