hi there should be a code on the screen when the wrench appears.the code will lead to identifying the problem.hi
You can't post conmments that contain an email address.
Call Service and Communication Errors are usually relating to an internal mechanical fault that needs to be addressed by a Authorized local Panasonic servicer.
You may try to reset the unit using code: [MENU] [*][8][0] [SET] or [START]
You may also call - 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
OK the nearest one to Hayward is the Factory Service Center located at Bosch/Skil Service Center 4980 Landon Dr., Anaheim CA 92807 or call toll free 1-800-346-4103. You can also go to Skiltools.com and type in your zip code to find the nearest authorized center within a specific radius. Hope this helps
This blinking wrench red light means that your copier needs to be serviced. How old is your copier or how many copy have you done with it ?
Otherwise, you may need to call a service man for it.
If you have a Kitchenaid Blender (model KSB50B3 or similar) and the rubber teeth on the coupling (that spikey rubber thing on top of the base) broke off (see picture), here is how you can fix it yourself!
The Task:
The coupling is screwed onto a vertical shaft like a button
mushroom. The shaft is round with two flat sides. You need to find an
U-shaped thing [such as a wrench] to secure the shaft and loosen the
coupling by turning it CLOCKWISE.
What you need:
1. New coupling: Part number KA-9704230. Shouldn't be more than $6. I got mine at www.goodmans.net. Their shipping fee is very decent and the service is also good.
2. An U-shaped object: Some had success with household forks. That didn't work for me. Most successes came from the use of ignition wrenches. There's
only about 1/4 of an inch between the coupling and the base,
and these very thin wrenches can get in there. You will need size 5/16
or 9/32. I got mine at Sears. They come in a set and are not cheap!!
The steps:
1. Rip the rubber cover off the coupling. There's a metal disc inside.
2. Secure the shaft with the wrench.
3. Grab the metal disc with a plier and quickly **** it CLOCKWISE. This is to overcome the inertia.
4. If not loosened repeat steps 2~3.
5. Screw new coupling on COUNTER-CLOCKWISE.
Now you are ready to make that smoothe or margarita or what have you again!
Disclaimer: Kids,
don't do this at home. I am not responsible for any explicit or
implicit damages caused by you repairing your blender. Read
manufacture's warranty policy before proceeding. Call their service
center if you don't feel comfortable performing the aforementioned
repair.
hi
