Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Can you help
Can you please assit in taking our S400 apart. We have the whole E18 thing going on and Canon will only replace the camera if we pay for it. We have sand it it probably
Thanks Teri
Posted by Jersi on
CameraR
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Recommend trying and re-trying the above methods to fix your camera. They usually work. Really don't recommend digging into your camera to fix it as it is very involved. Here's an example E18 disassembly repair for an SD300:
http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
Posted on Nov 19, 2007
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Canon Ixus 40 E18 Problem
try this link for E18 error in canon cameras for instructions
pls rate me FIXYA for help
Apr 08, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera will not stay powered up and lens won't come out
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 15, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
E 18 problem
i had this problem with my camera the same make it happened twice and E18 appeared both times its a fault with the lens its has been knocked out of place and thats why it will not close mine was because it was dropped on the floor with the lens out! i blagged to the company that i brought it from that it just happened and they swapped it for a new one both time in the shop. its worth a try
Dec 01, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
E 18 problem
Your first problem sounds like a defective CCD imager. If your camera was an S300 Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Unfortunately, you mention that your camera is an SD300. That model camera is not currently on the recall list. But you might want to call Canon anyways. You might get lucky as the problem sure sounds familiar to the recall (excuse me, advisory hehehe).
As for the SD500 with the E18 error, try http://www.e18error.com/repair.html
Nov 13, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
E 18 problem
Your A410 problem really sounds like it might be a defective CCD imager. Canon would normally fix this for you for free, including free shipping both ways. http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Unfortunately this is only for applicable cameras A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
But you may want to contact canon anyways to see if they will help.
As for your SD500 e18 issue,
Nov 05, 2007 | Canon PowerShot A410 Digital Camera
E18?
Click here for help on repairing e18 error
good luck my friend!
Hope you will save 150$ for the repair..
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
E18 problem - zoom lens does not work, can't take a picture
If you can find this crappy site, then you must have enough talent to find canon.com. Duh?
Aug 26, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
E18
E18 indicates a lens or "optical unit" problem. In other words your zoom lens won't function correctly. Canon will be more than willing to look after you.
Mar 29, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
