Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
If you do not have the manual for the remote the codes needed for the DVD player must be present on the list. Please check if the following codes will help:
Helo If the remote control you uses with your Hitachi is a universal one, there will be some malfunctions occur with remote button presses and TVs response. If it is its original one, the remote controls keypad circuit prints comes at the back of keypad is dirty. You have to open it, and clean it with medical quality turpentine or recitfied spriit. Never use hard solvents like petrol or so, as it will damage the rubber pad of the remote control.OK.
Hi my nameis Mike Houston of DISH Network; I was going over your post and see where youwant the Hitachiremote to work the DISH receiver and your DVD. The best thing to use is theDISH Network remote to use all the functions of the receiver; I will send thislink http://www.hitachi.com and theinstructions of programming the Hitachiremote.
I have Hitachi universal remote CLU - 5729TSI how can I Program it to change the code for a different tv. a toshiba 36 inch it is around a 1999-2000 model.
First, there is no such thing as a 'universal' remote. There are numerous makers of 'multi-brand' remotes and they just lie a lot; they need to be sued.
Your Emerson is made by a company named Funai who also makes 'stuff' under the names below:
Funai, Symphonic, Sylvania, Aventura,
Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
You might try any (or all) of those to see if your Hitachi remote has codes for those brands.
You won't be able to use it for your dvd player unfortunately.
The code for sky is 0145.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful.
i have a memorex dvd and want to use my 4324ug remote?
