Bose Cinemate Digital Home Theater System Speaker Logo
Posted on Jun 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bose Cinemate green led won't come on.
Remote works on all over devices but the Bose speakers. New batteries and unplugged power and plugged back in but no change.
Anonymous
Level 2:
Sniper:
  • Expert 71 Answers
  • Posted on Jun 13, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
71
Questions
Helped
79679
Points
274
Do the same thing by unplugging the power, but also unplug the interface module (box with red/green LED light) from the sub woofer / bass module, and wait 30+ seconds. Plug the interface module back in first, and screw it in as tight as possible. Then plug the power back in and try the remote. This should fix your problem. :)
If this doesn't fix it, you will have to purchase/replace this module through Bose. (anywhere from $40-$60 if not under 1-yr warranty.) If you're still under warranty, it's a free replacement.
1helpful
I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
2helpful
Remote won't turn on the system. Has new batteries. The tv button lights up when I push power. How do I set it back to control the bose cinemate?
Unplug the speaker plug and the power plug. Let it sit for a minute. Plug the speakers in and then the power and try again. Hope this helps.I have seen this many times and this is usually the solution.
6helpful
3answers
Bose cinemate will not power on. light stays red?
Make sure your system is not plugged into a surge protector. Sometimes a surge protector will foul the system up, don't know why. lol. I fought with my system for 3 hours trying to get it to work, then moved it from my surge protector to the wall and it came on. If that doesn't work, try disconnecting the receiver module itself, wait 60 sec, then plug it back in. If that still does not solve the problem, I would suggest calling Bose Customer Service..
Remote does not turn on interface modual
Unplug mains power to amplifier for 2 hours. Powered up and back in control.
No green led light on bose cinemate system
I had the problem, after a lightning surge through our house, that destroyed item connected to the telephone lines. The Cinemate interface unit stayed red (powered), but could not get green light to come on, and obviously no audio. Found through Bose tech support that the the units are failing from surges "too often". They are trying to find out why and fix the longterm problem. Tell them you had a power surge (which you likely did), the green light won't come on, but the remote works with TV, etc. They will send a UPS Return Tag for you to send back the small interface unit (only). Upon receipt, they will 2-day air you a new one. It solved the problem.
1helpful
3answers
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
1helpful
3answers
Cinemate bose home theatre system
called bose they said to unplug the actual reciever piece from the back of the sub and to wait 60sec and plug back in and turn on. they also said that sometimes a surge protector can cause the remote to foul up
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
