Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G self propelled drive unit locked up
The self propelled drive unit on my kirby is locked up.  The rear wheels will not turn with the switch in "n" or "d".   Is there any way to release it manually so I can run it before I take it into the repair shop?
Posted by Anita Dunt on
Lauren Junge
    President:
  • 1,673 Answers
No, you just need to take it to a shop for repair.
Posted on Jan 06, 2008
Anonymous
  • 4 Answers
If you're still looking for a shop to fix your Kirby, try www.sparesaver.com as they have a Kirby repair centre.
Posted on Jan 11, 2008
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 self propel problem
There is an adjustment for the transmission and it is wrong. It could also be worn. The Kirby has an amazing warranty. See if you can get it serviced for free.
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Self propel lever
contact your local kirby agent for repair or kirby.com
Apr 13, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Is there some trick to putting a transmission belt on a kirby gen. 3 ?
It would be very unusual to have a transmission belt problem. To access the belt; the handle, and switch cover plate are first removed. Next remove the 4 screws that hold the upper motor cover in place. Next remove the switch button by prying up gently on it's attaching lugs and pull it free of the switch actuating rod. 3 screws hold the transmission to the base. DO NOT remove the screw in the rear beneath the on/off pedal. By dropping the power drive assemby slightly down, you should be easily able to remove the belt.
P S: I have repaired 100's of power drive Kirbys, and have never seen a bad power drive belt. If the self-propel seems to work poorly, it is usually because the rear wheels are worn out.
Feb 02, 2011 | Kirby Vacuums
Kirby Ultimate G wheels lock up when in drive...
Replace the transmission. The tranny that drives these Kirbys can give you problems.
May 16, 2009 | Kirby Ultimate G Bagged Upright Vacuum
G-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Diamond Edition
If this is a Hoover vacuum, which model is it?
Jan 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
489 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Susan Jamieson
Level 1 Expert
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
