Question about HP Photosmart R817 Digital Camera
Card cant delete it says card is locked
Posted by buck123 on
Anonymous
  • 589 Answers
There is a little slide switch on the side of the memory card. Good luck!
Posted on Jan 08, 2008
What does it mean when it saids your memory card is lock I haven't lock it.Please help Thank You
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 07, 2012 | Panasonic DMC-FZ35 Digital Camera
I have a samsung wb690 and i cant take any photos as card locked comes up
SD cards have a slide switch along one edge.
Feb 03, 2012 | Samsung Cameras
Cant deleted video locked need to unlock it
You will see a small slider switch on the thin edge of the SD card.Slide it to the other position then the card can be formatted/erased.
Al
Dec 26, 2011 | Speed HD-9 Camcorder
Cant delete pictures from camera.card locked showing
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 19, 2010 | Canon Cameras
My sd card in my cell phone is saying its locked and i cant unlock to delete my photos
Oct 31, 2010 | Jazz DV-179 Digital Camera
I cant take delete, or move photos from my sd card, If i try to do anything with the images on the card when its plugged in to my computer a pop up comes up saying 'Cannot move 4267_180627790516_589680516...
is the card lock slider on? look at the card, there is a tiny switch that says in tiny letters lock, is that moved to the lock position? the little slider is on the left side of the card with the SD Logo label
May 07, 2010 | PNY 2GB microSD Memory Card
Write protection problem on Motorokr E6
Hello. I am having a peculiar problem with my memory card on my Motorokr E6. It always write protected even when the lock on the card is ''free.'' I can access it from a PC using windows Vista but cant add/delete content to card while using XP.
Dec 18, 2008 | Motorola Mobility MOTOROKR E6
Card locked
move slider switch on side of memory card to unlock card
May 16, 2008 | Samsung Digimax D53 Digital Camera
Sandisk Sd card
there is a small switch on the side of the card change its position.Its there so you cant accidentally delete stuff thats important you may have moved it by mistake
Nov 21, 2007 | Cameras
HP Photosmart R817 Digital Camera Logo
Top HP Cameras Experts
Paul Green
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
