Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The compressor starts, (or tries)for ~ 3 seconds, stops. retires ~ 15 seconds.
Posted by foamist on
Bailey's Appliance Service
  • 222 Answers
You either have a problem with your compressor start relay/overload assembly.......or you have a bad compressor. You would need the model/serial number for the correct part. If the unit is out of warranty, a 3 in 1 hard start kit (Supco URCO41) can be installed. Disconnect unit from power prior to attempting repair, and follow the instructions with the part.
If the product is under 5 years, the compressor may still be under manufactures warranty. In that case attempting a repair would void the warranty.
Posted on Jun 07, 2009
Why is the compressor not turning on?
Very likely the little 12-volt fan motor in the freezer compartment has failed. The compressor will not start until that fan motor is running. Pull the plastic fan cover off (screws at top corners) and with the refrigerator plugged in, watch the fan for movement. It will spin and stop about ever 15 seconds. Unplug the fan connectors and the compressor should start in about 30 seconds. Replace the fan motor.
Mar 07, 2015 | Vissani 3.1 cu. ft. Mini Refrigerator in...
Manitowoc Compressor (QY0424A) Starts and Stops
ou are in the wrong product category
Sep 21, 2012 | Cars & Trucks
Compressor starts and runs for 15 seconds and stops. tested capacitor 15 mfd .i can hear the start relay open on start up and compressor stops . can it be the relay.
Its possible to be the relay, but if you have access to an amp meter I would see what the rating for your compressor is, it will be on a tag on the compressor, and see if its drawing too much or too little. That way you know if the compressor is bad. I've seen too many times on that particular brand techs change the relay just have the compressor fail two weeks later.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 26, 2012 | Frigidaire FRS26H5AS Side by Side...
My whirlpool fridge freezer keeps making a clickin noise like theres an airlock wot can i do to stop it?
Hi and wlecome to FixYa, I am Kelly
First off unplug it for about 15 -20 mintues. If there was a momentary power loss the compressor may be in a high coolant pressure fail to start situation. The high side pressures are well in excess of 150 lbs and the coolant system needs to stabilze for about 15 minutes so that the compressor does not "dead head." The clicking sound your hearing is the start winding trying to start the compressor. If it does not reach full speed in about 45 seconds the Klixon thermal overload will cycle and there will be a 4 - 5 minute pause before you hear the clicking again as the compressor again tries to re-start.
After unpluging the unit and then restarting it... if it does not re-start then there are a couple of things that can cause this.
1. The PTC relay mounted on the side of the compressor has failed.
2. The run capacitor has failed.
3. The compressor has failed and the internal rotor has LOCKED.
Unless your electric bill has been steadily climbing over the last few months I doubt that the comressor is locked,
Since you did not include a model number this is a GENERIC response without any parts links for the PTC relay or the run capacitor. If you need help with parts or further troubleshooting please provide a complete Model number in any future responses.
Thanks for choosing FixYa.
Kelly
Jan 29, 2011 | Whirlpool Refrigerators
I have a Kenmore Coldspot Model 106.7629461 Here's the problem: When the unit needs to run to keep the freezer/refrig cold, it does so for about 10-15 seconds. Then it shuts off for about 2-3 minutes. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Kenmore Refrigerators
My air compressor makes a noise like a lawn mower traying to start after it kicks on, after about 15 or 20 seconds for about 2 seconds and then the noise stops. Dont do it all the time. It runs good pumps...
Isn't the air compressor just charging or is this a new noise that you didn't hear before. If it isn't broke don't fix it. It could be a valve that isn't opening and closing properly. Use a little pneumatic lubricant on any parts you feel confortable getting into. Don't disassemble anything unless you know how to put it back together. Pay attention to direction of valve spools.
Sep 30, 2010 | Ingersoll Rand - Rand Type - 30...
Compressor starts for about 2 seconds, stops and then starts again for 1 second then stops again for a few seconds and then starts again for a second. Is it the pressure switch assembly? Thanks,
Yes it is the pressure switch ***.If you have been adjusting it,this maybe the problem,if not,replace it to repair the problem,and thank you,please rate.
Jun 15, 2010 | Coleman 5.5HP 15 Gallon Verticle Portable...
Compressor ticking noise on start up.
could try a hard start kit, sometime do not hold up for tp long?
Apr 10, 2010 | Refrigerators
Whirlpool refrigerator
you can try replacing the overload relay mounted onthe side of the compressor ( kit number 4387835) sounds like its gone bad, trying to start yor compressor, but tripping off on overload.
Jan 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
178 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
