Question about NorStar Compact Ics WithClid Trunk Mod (ntbu0686)
NorStar ICS Caller ID Upgrade
I have a NorStar (Nortel) Compact ICS with a standard Norstar LS/DS Trunk Cartridge.  This setup doesn't support Caller ID.  Can I simply power down the ICS and replace the LS/DS cartridge with a Norstar Caller ID Trunk Cartridge NT5B41GC NT7B75AAAE NT7B75AAAF power it back on and CID should work, assuming that I have CID enabled on my CO lines?
No feature options, software configuration, or firmware upgrades needed?  Simply power off, pull old cartridge out, put new cartridge in, and power back on?
Posted by shinerblue on
Anonymous
  • 60 Answers
Yes, this is correct. install the co card with cid and you should be fine.
Dan
Posted on Jul 29, 2009
How do I reset my phone system? Nortel Norstar
It's simple.
On Vmail it's Ftr 983 -> pswd -> 1 -> reinstall -> yes
On MICS it's pull the power plug off and within 15 minutes -> Ftr** -> startup -> pswd
To be sure follow the users manual instructions. You can get the pdf user manual here: Nortel Norstar pdf manual
Sep 17, 2013 | Nortel Norstar Compact ICS 6.1 Software...
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Network passport router login and password information
This is all i could find
Nortel Norstar Modular ICS Any **ADMIN (**23646) ADMIN (23646) Nortel Norstar Modular ICS Any **CONFIG (266344) CONFIG (266344)
Jul 27, 2010 | NorStar Passport 2430 Router
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Attendant still completes call after caller hangs up
Check and make sure that the disconnect clear time of ur Norstar is 800ms.
Apr 02, 2009 | Ics Norstar MICS (0x32) Modular Cartridges...
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
Norstar compact plus- can't get line access
make sure your wiring the co lines on the first 2 pins of the 66 then space 2 then lines 3 and 4.
Dan
Dec 09, 2007 | NorStar Nortel Venture EFA Phone
NorStar Compact Ics WithClid Trunk Mod (ntbu0686) Logo
458 people viewed this question
Top NorStar Computers & Internet Experts
Vincent G
Vincent G
Davit Mamyan
Davit Mamyan
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
