Question about Samsung HP-R4262 42 in. Plasma Television
Large black line top to bottom
HAVE A SAMSUNG 42 PLASMA MODEL R4262 WITH A LARGE BLACK LINE IN THE CENTER OF THE SCREEN FROM TOP TO BOTTOM. IS IT FIXABLE???
Posted by swipe on
  • yosemite Nov 15, 2007
    Thanks for a great site. Your help is much appreciated. My Samsung HP-R4262 shows a black bar vertically on the left-middle of the screen covering the TV image. The bar is about 4 inches thick and has a thin green line running down the center. Any idea how to fix this cheaply? Thanks again.
  • Anonymous Nov 16, 2007
    My Samsung is three years old and just developed a black line that runs from top to bottom. The line is about one inch wide. I'm looking for a solution.
Anonymous
  • 579 Answers
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Posted on Dec 31, 2007
Black line about 5" wide
one of your buttom scanning bords is dead or it needs to be cleaned or simply reconnected properly , at the buttom of your plasma tv you have 2 to 4 small boards with flex connecters one of these flexible connecters will be adjacent to the black line ,replace entire board because it cannot be repaired
Sep 05, 2011 | Samsung HP-R4262 42 in. Plasma Television
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Samsung plasma tv hp-r4262
The x drive board is bad in the area you see as black. OR the cable came loose.
Jul 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
Mar 10, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Black line
Dec 11, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung HP-R4262 42 in. Plasma Television Logo
282 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
