Question about Kenwood KDC-519 CD Player
Kdc-519 install in 93 mustang
Having a hard time with the wireing. power it up and hook up speacker and they dont work. do i need to jump any wires on the factory harnes to make it power the speackers
Posted by tntwalsh719 on
Anonymous
    Problem Solver:
  • 13 Answers
If u have cut the factory harness, then u may have cut the power on wire for the factory amp
Posted on Jun 07, 2009
Subs make one very loud bang when car starts i have a kenwood kdc 528 deck and 2 pioneer 12in subs an amp
Hook it up properly to the deck remote on wire ,(Dude) End stay off the (Drugs)
Nov 22, 2012 | Pioneer Car Audio & Video
Im trying to hook up my radio to a 93 ford mustang and ive got power and i got the speakers hooked up right but i dont have any sound
Is the radio powering up?
Have you tested the continuity to the speakers (disconnect speakers and use multimeter on low ohms across speaker wires, you might also hear a crackle if speakers are ok)?
If you dont have a meter use a small preferrably used battery (take one out of the tv remote) and dab across the speaker wires briefly, you should hear a click from the speaker.Make sure the speaker is disconnected from the radio when you do this!
Have you connected the ground?
Did the the radio ever work?
Have you connected the antenna?
have you tried any old small speaker hooked up to the radio output?
Ahhh questions questions....
Feb 26, 2011 | Ford Mustang Cars & Trucks
I install a radio it dont keep a memory
Pull the radio back out. I bet you hooked up both power wires (red and orange or yellow) to the ignition on hot wire. Orange or yellow depending on the radio usualy goes to the ignition on hot wire and red to a constant hot wire. Check the radio wiring diagram or list. One of the power wires has to go to a full time power source. check the wires with a circuit tester with the key off till you find the constant hot wire (battery power)
Dec 17, 2009 | Kenwood KDC-MP228 CD Player
I have a kenwood kdc 233 cd player in my car but the remote wire aint working because i tried hooking up an amp i pit a light power tester on the remote wire but dont work and i dont think the input plugs...
as far as the remote wire a keyed power wire from under dash can be used its the same thing.if the remote wire is working it wont turn on your amp so are you sure thats not why your rcas dont work or have u hooked power to the remote on the amp.
Nov 09, 2009 | Car Audio & Video
I am trying to install a deck in my car. I hooked up all the wires and the deck (kenwood kdc-7007 worked at the store we bought it. There is power coming from the red wire in the car but doesn't power the...
did u check the fuse in the back of the radio?did you check the radio fuse in your car? Do you have the yellow battery memory wire hooked up? Is the black ground wire connected
May 18, 2009 | Kenwood KDC-7007
Need a wiring schematic KDC C717
Black typically goes to ground.
Red goes to battery (+) (+ all the time)
Yellow typically goes to switched power (+ when ignition in run position)
Mar 06, 2009 | Kenwood KDC-C717 10-Disc CD Changer
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
No sound
I just installed an aftermarket radio in a 93 mustang and I had to hook up the blue wire for the power amp to work. I am not an expert just passing on what fixed my problem. Good luck
Dec 08, 2008 | 1999 Ford Taurus
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
May 28, 2008 | Kenwood KDC-2011S CD Player
No sound thru cd player
are you using any separate amp?- if you are the blue wire on the back of the radio is probably turning off when you use a cd(the blue wire is for a power antenna, the blue with a white stripe is for an amp)
Feb 29, 2008 | Kenwood KDC-519 CD Player
Kenwood KDC-519 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
