Question about RCA OPAL M4001 MP3 Player
RCA Opal Not Recognized
I thought it was just my computer first, but have tried it on numerous computers. I plug it is, and it comes up on the task bar, but will not show under my computer or Windows Media Player in order for me to add songs.
It charges fine, but I CANNOT any new music to it as I can't access the files from any computer.
Help!!
Posted by Kylee84 on
  • 7 more comments
  • Anonymous Nov 06, 2007
    Mi opal M4002 cuando lo conecto a mi PC no es reconocido por el sistema (windows XP y Windows media 10) ademas cuando lo enciendo sale un mensaje en pantalla que dice ¨profiling need 4 MB¨e inmediatamente se apaga el reproductor
  • Anonymous Dec 01, 2007
    same thing here rca has sold me a shiny red turd!
  • temosachic Dec 04, 2007
    i bought a rca opal mp3 player but when i connected to my computer its says something about opal what do i have to do
  • Anonymous Jan 06, 2008
    Same problem. The opal is not recognized on my computer, but is recognized on other computers. Must be a computer problem, BUT WHAT???
  • Anonymous Mar 07, 2008
    Same exact problem%$#&&^$*^%(*)_!!!
  • aabaas May 29, 2008
    I Have the same Problem and when I removed it from my computer and reinstalled it my computer said that there was a problem installing it therefore there may be a problem with the device working properly. I NEED HELP!!!!!!!!!!!
  • WeezyJC Jun 04, 2008
    This happens to mine. Except mine wont charge it just says charging building database forever and wont turn on it also isnt recognized by any computer.
ThaMp3Doctor
  • 8,597 Answers
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Posted on Jun 18, 2008
My rca opal mp3 m4204 4gb is not recognized by my computer
Try plugging it on an another computer. Maybe the USB port is in problem if it cannot powers up the player.
Jan 11, 2009 | RCA M4204 MP3 Player
RCA M4204-A freezes at the OPAL initializing.... screen and is not recognized by the computer.
There are a few things you can do.
One plug device into your usb of your computer.
Use the add new hardware fuction.
Have the computer search for new hardware.
It should not be able to find the OPAL.
After it fails to find the OPAL have the new hardware wizard look for MPT device. It should find it after that.
If it still not found bye the pc.
Goto RCA website and download the newest firmware.
http://www.rcaaudiovideo.com/
Find your make and model and download the firmware.
After the new firmware is download make sure your OPAL is still connected to your usb device on my pc.
And install the new firmware. While the firmware installs windows should find the device.
Jan 10, 2009 | Audio Players & Recorders
When plugged into computer the computer shows malfunctioning and device not recognized wont come on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 09, 2008 | RCA OPAL M4001 MP3 Player
My RCA OPAL
everytime i use to try to turn it on it would say please wait then please reformat me then it would never come back on. now it does not come on at all. and it does not do nothin when i plug it up to the computer
Mar 29, 2008 | RCA OPAL M4001 MP3 Player
Rca opal
Feb 19, 2008 | RCA OPAL M4001 MP3 Player
Rca opal
Feb 17, 2008 | RCA OPAL M4001 MP3 Player
RCA M4018 8GB MP3 Player
Mine didn't recognize either, so what I did is go into the device manager, find the opal in the listings, double-click, disabled the device, re-enabled it, at which time it shows that there's a firmware error. I then re-installed the driver from the cd, unplugged the opal, plugged it back in, and for whatever reason, the computer then recognized the opal as a mass storage device, instead of a portable music player. The computer now sees it everytime, and all I have to do is drag and drop any files I want into the opal. Works like a charm. Hopefully RCA will provide an updated firmware program in the near future, but this might work for you for now. Good luck!
Feb 10, 2008 | RCA OPAL M4001 MP3 Player
Will not download songs
i had the same problem. and the answer made me so mad. turns out, you have to have yahoo unlimited TO GO in order to transfer the songs. i found this out after not only suscribing to y! unlimited but also downloading 400 songs! ugh. i still haven't found any service that works with it, and i've been searching all day.
Dec 25, 2007 | RCA OPAL M4001 MP3 Player
Opal m4001 wont turn on
Reset the player first, and then try again
Dec 24, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
254 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
