the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
This type of generator has an oil-level sensor to prevent operation when
it is too low. They burn oil pretty quickly, and 138 hours may have put you below the minimum. Check to see that the oil is filled to the right mark on the dipstick, and be sure it is on level ground when you do this.
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
