Question about Yahoo Messenger
Cannot sign in yahoo messenger
Cannot sign in to yahoo messenger almost 6hrs and i try to uninstall yahoo messenger and then i install new yahoo messenger at during launch the ym and sign in, the problem are 81003002. please kindly help me to this matter. thank you.
Posted by jhess_astig1 on
A.A.K
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
It may have 2 problems and 2 solutions:-
Firstly, this error occurs when your connection preferences are notproperly set. I'm not talking about your Yahoo! ID and Password here,but you may need to adjust certain features depending on what networkyou're on. Let's says for example, if a firewall protects your network,it may block yahoo messenger when it tries to connect to the server.You need to change your connection settings, click the Messenger menuin yahoo messenger and select Connection Preferences. Select FirewallWith No Proxies. Select your Internet Connection type from thepull-down menu at the bottom and enter your Home Country if theseoptions aren’t grayed out. Click OK and login again using the newsettings.If this option doesn’t work, click Connection Preferences inYahoo! Messenger again and select No Network Detection. Try to loginagain using the new settings. In some instances, you may need toprovide yahoo messenger with the IP address of your firewall or proxyserver (you can get this information from your network administrator orfrom your Internet service provider). Click Messenger and selectConnection Preferences again. Select Use Proxies. Enable either theHTTP Proxy or the SOCKS Proxy as needed and provide the proper address.Click OK and login again using the new settings.
Secondly, if you are using IM9 there are sign in problems. This is whatyahoo has to say.Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issuesthat have been affecting some users. If you were seeing an error code“81003005” when trying to sign in, this latest version may fix thatproblem. Even if you were experiencing a different kind of sign-inissue, I recommend installing this latest version.
Hope it can be helpful!
If you satisfied with this information, please do support me...
Thank You!
Posted on Jun 07, 2009
Cannnot open yahoo messenger
For that's problem uninstall first your yahoo messenger. click start > click Control panel > click Add and remove programs and choose yahoo messenger programs then uninstall. if finish uninstall restart your PC. and install again to download yahoo mesenger latest version click the following link http://messenger.yahoo.com/download/ . if finish downloading double click msgr11us.exe, follow software step by step installation instructions. if finish try to sign in.
Let me known if not yet open your yahoo messenger. Regards
Jul 23, 2011 | Yahoo Messenger
Why i cannot sign in in my yahoo messenger?
Try restarting your computer and then logging in.
If the problem persists try the following-
1) Ensure you are connected to the Internet.
2) Create a new messenger account
3) Uninstall and re-install your messenger by going to Control Panel > Programs > Uninstall
Hopefully one of these solutions will help
May 16, 2011 | Yahoo Messenger
Am unable to see messages which am sending & recieving in instant chat
First try sign off and sign in for few times , if you still face the problem then uninstall the yahoo messenger and reinstall
Even i also faced the same problem , For few times sign off and sign in had worked or even restarting the PC also worked.
But after uninstalling and installing the yahoo messenger i got rid of the problem
If uninstalling and installing the yahoo messenger also not work then follow the below two steps
STEP -1
go to Start Button - Run - type regsvr32 jscript.dll - then press OK
STEP-2
go to Start Button - Run - type regsvr32 vbscript.dll - then press OK
now your yahoo messenger will work normally.
goodluck
Jan 13, 2011 | Yahoo Messenger
I cannot sign in
uninstall messenger and install it again ....
Sep 29, 2009 | Yahoo Messenger
Cant sign into yahoo messenger
First try to uninstall and again install new Yahoo Messenger. If it still doesnt work, you have to reformat your system. It happened because your system is infected by virus which severely triggered some features of your Yahoo Messenger or maybe your Drivers.
After reformatting your system your YM will surely work.
I am expecting your comment.
Feb 27, 2009 | Yahoo Mail
Signing problem at yahoo messenger
Hi ,
Uninstall this yahoo messenger and install new one and also install proper antivirus software.
Regards,
Chetan
Nov 22, 2008 | Yahoo Messenger
Signing on to yahoo messenger 900-2034.
try uninstall again the yahoo messenger select complete uninstall, remove also backup data if system ask and after uninstall complete go to C:\Program Files\Yahoo! folder and delete Messenger folder, remove also in recycle bin, restart your computer and install yahoo messenger again. I suggest to install the Yahoo Messenger Full Standalone Installer, you find this at google search.
Nov 18, 2008 | Yahoo Messenger
I cant sign in yahoo messenger
please solution the yahoo messenger
Oct 10, 2008 | Yahoo YHT-630 System
PROBLEM SIGNING IN YAHOO MESSENGER
uninstall yahoo messenger from your computer
restart computer.
defrag drive,
delete temp files in temp folder:
start>run>%temp%...delete
start>run>temp...delete
start>run>prefetch...dlete
now try reinstalling YM. download the installer from majorgeeks.com
dont do the online install. this will work now
Mar 25, 2008 | Yahoo YHT-630 System
Yahoo messenger sign in
Hi, your computer has been attack by a virus, you have to find a new virus scanner to get the virus.
Dec 01, 2007 | IBM xSeries 346 Server
Yahoo Messenger Logo
848 people viewed this question
Top Yahoo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
