My windows media player has stopped working in laptop (4 yrs old)
It worked fine until 2 days ago. Only thing different is I installed upgrade to Adobe 9 but don't think that should have affected it.Laptop is about 4-5 years old. Thank you for any suggestion .
Re: My windows media player has stopped working in laptop...
Try doing a system restore and check if it works fine note:- if you do a system restore all the recent applications will be lost and you will have to install it again.
No, there aren't any settings that can change graphic resolution on streaming video. However, you can visit the following website to update your drivers for your video card:
http://www.nvidia.com/Download/index.aspx?lang=en-us
There are two options on the website; option 1 is to fill in the info of your graphics card, and option 2 allows the nVidia website to scan your computer's hardware to find any updates needed. Option 2 is probably the safer route. Continue to follow the instructions until you have updated your graphics card drivers. This should enhance streaming video resolution.
Make sure USB mode is MSC....If this doesn't work make sure that you are connected to a 2.0 USB port....I had to install the update on to my labtop and finally it recognized it and updated.... Download Update if you haven't yet(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) this comes with A mediA converter ...Try and drag and drop from your music folder to the media folder on the player make sure usb mode is mtp this will show you all the folders Use your windows explorer for the transfer... much easier..... Then connect to your computer and see if it works Hope it does..........Please rate
I just fixed the problem I was having (after 2 days of trouble shooting and on the phone with Norton anti-virus). Somehow, the Bonjour program got deleted from my computer. I think it happened when Norton was upgraded and renewed on my computer because I'd done nothing different up until that time. Here's how I fixed it JUST NOW. I went to:
heres a suggestion go back to xp service pack 2. service pack is very easy to use and more compatibility than sp3. right now my 10 pc's are all xp sp2 and they have no problems about the sound.hope that helps
Ahh - you have Vista! You MUST get the newer version of the software from www.usasupport.philips.com. Enter your model number and go to the "software & drivers" section. Download the updated version of the device/firmware manager. Once the Vista-compatible version of the software is installed, then you can go to the Update tab and the firmware upgrade that you need will be installed - you will not get the "your player's firmware is already up to date message."
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
We had the same problem with Windows XP. We found some help on the Sandisk web site. On the device go to the Settings menu, then USB. We changed from AutoDetect to MSC mode and everything is working again. Our computer saw all of the songs on our computer fine. Some of the old songs on the Sansa didn't show up on the detect list in Windows Media Player, but they were still on the device.
I know this request is old, but I found it while searching for an answer to the same problem myself.
First you need to go to the Rio site and download the most up-to-date firmware. it DOESN'T matter if it's the same version that you have now, you will need the installer program.
Download that and install it.
Plug in your player to your USB to your computer - BUT (and here's the important part) you need to hold down the menu key while plugging it in. Keep holding until it powers up AND the word "UPGRADER" shows on the screen.
Now, run the firmware upgrade program and it will see your player and upgrade the firmware (yes, even if it's the same firmware version. You have to do this step).
Once it's completed, unplug the player from your computer and the darned thing works.
