Question about iLO (2 GB) MP3 Player
My MP3 Player is Showing blue screen only
Dear sir,
             When I switch on MP3 player it shows blue screen only with sand timer pot in the centre.reviously it showed it and after few seconds it would show "Intialising" sign.Then all buttons would function.Now no button works.Only blue screen is there whenever I switch it on.What can be the problem.
Hope to hear from you.Thanks
ML Dewani
INDIA
Posted by ML Dewani on
  • bub hover Mar 26, 2008
    all i get is a blue screen i dont get nothing else
ThaMp3Doctor
  • 8,597 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
No options as i switch it on..
sir, for the transcend mp3 players there is no special options like the switching it on.you just need to hold the play/pause button for few seconds.there may also be a charging problem.charge it totally and try it again.
May 24, 2009 | Transcend T-Sonic 840 MP3 Player
Sandisk 2GB
You can go into the settings menu and change your backlight and screensaver settings so that it doesn't go off every 5 seconds. Your user manual, which I have provided a link for here, will show you exactly how to do this:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Mar 24, 2009 | SanDisk Sansa Clip MP3 Player
Starting up
try to on it... by pressing the play button or on button by pressing it for few seconds... else try to format or update..
Jul 03, 2008 | Sony NWZ-B103FBLK MP3 Player
Problem in sofware
switching to recovery mode is easy. simply connect the device to your computer, then push over the hold button so the orange is showing. next push and hold the record button and at the same time push and hold the power button. after a few seconds it should go to recovery mode. best of luck : )
Feb 14, 2008 | SanDisk Sansa e260 MP3 Player
ON sign shows blue screen only in my MP3 player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
This looks like the software has corrupted on your mp3 player. In order to get it working again you may need to format it by either using software which came with the mp3 player when your brought it or use the simple way through "My Computer".
If you haven't got any software follow these simple steps. Click "Start" located at the bottom left, now click on "My Computer", now when your on My Computer look for your mp3 player but don't click on it just find it on there (It's usually called "Removable Disk" right-click on it and click "Format".
Allow it to format then try unplugging it and switching it back on and see if it's fixed the problem.
If it doesn't may need to download some firmware of the manufactuere website. I have found some firmware which may be yours you may need to download and check
https://system.netsuite.com/core/media/media.nl?id=16075&c=432868&h=68a87fdefb1fe2d5903b&_xt=.zip
Good luck. Hope my solution was helpful.
Oct 26, 2007 | iLO (2 GB) MP3 Player
Screen shows sand clock
press the menu and center button together for about five seconds to reset it see if this helps
Aug 14, 2007 | Apple iPod nano
I hate blue
goes off because the backlight is on a timer. after 20 seconds or so it turns off if no buttons are pushed. if the player will still play music but nothing shows on the screen, then the display is shot. The screen is not replaceable on these players. sorry, but it's most likely junk now. You could use it as a data storage device still. Best bet is to buy a used player off ebay or amazon.
Feb 11, 2007 | SanDisk Sansa e130 MP3 Player
iLO (2 GB) MP3 Player Logo
37 people viewed this question
Top iLO Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Marvin
Marvin
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
