My battery keeps draining and i don't have any idea why..ive changed the alternator and the battery could some help
All you need is a ammeter,
to find this.
this is called phantom drain. (something is stuck on)
here is all ways to find it.
http://www.fixkick.com/drain/drain.html
SOURCE: 1996 geo prizm
you'll have to pull off the interior panel. window in the up position. on the lock cylinder there is a clip that you have to pull off and an arm that actuates the lock. pop the lock out. reverse to install.
SOURCE: 1994 GEO Prizm Fuel Guage
You need to replace your fuel sending unit. It is located inside of the gas tank.
Please remember to rate this solution.
SOURCE: geo prizm stereo radio wiring diagram
1994 Geo Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
