Question about Electronics - Others
My flash cant format
While am formating my genix flash memory,suddnly my computer shut off, now my flash just for reading and i cant format it again,
what can i do help me plz
Posted by omoalb on
rommel dadulla
  • 822 Answers
The problem is from your memory IC inside the Flash thats why refuses to format due to cold solder or some pins need fresh solder. so many times i fixed these kind of problem not only Genx.
Posted on Jun 07, 2009
Anonymous
Start > right click My Computer > Manage > Disk Management, and try formatting from there.
Samsung flash drive genix 4gb
you should format all programme of driver.
Mar 26, 2013 | Electronics - Others
I cant format my memory card and my cellphone cant read it to what should i do .
Get a Multimedia card reader for yourself. Plugin in the card reader in computer and insert the SD card in it. Once you see the SD Card in My computer that means your card reader is able to read the SD card that you have inserted. You can right click on the icon and click format. Do a quick format and choose file system as FAT32.
or
You can use SD Card Formatter and can follow their manual. I think that will also work for you. http://www.sdcard.org/consumers/formatter_3/
Jun 21, 2011 | SanDisk 2GB microSD Memory Card
My memory card show to format it when i attach it to my pc but after formatting i cant able to use it now what can i do
Soory dude very sorry to say that your card will never work again.
who said you to format the memory card with your pc. You doen't, every phone has a format opt for formatting the card. And in every phone's manual it is written that "Format your card with your phone option. Don't format with your PC It will pemanently damaged your card". So, formatting your card with pc will damage your card for forever.
Jun 16, 2011 | Cell Phones
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pc can't read it and autoplay doesn't stop popping out
if the autoplay option pops out after u insert ur memory card that means tat ur pc is reading it but the memory card may be corrupt slightly; for fixing tat try to format ur memory card , to format ur Mc go to "my computer" ur Mc icon is displayed there right click on tat icon ul find "format" option click on it n another tat opens press start wait till ur Mc is formatted then you remove n insert it again it will work fine
Sep 17, 2010 | SanDisk 2GB microSD Memory Card
I can't format my PNY flash memory, and when it be connected to USB port the computer speed decreased. Heip me please.
Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
Aug 03, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My PSP memory stick got virused. the problem is my psp cant read my memory stick, then i tried it to my computer but sadly it cannot be read as well but the removable disk [d] is there but cannot be open....
hi..
as you put in your computer the drive is getting detected so you can format it and it wil be fine. But formatting wil erase all your content in it and even the virus.
for formatting follow the steps
1.right click the drive
2.you wil have a option called as format
3.click on it.
4.click quick format
5.format complete wil come
after this this will work properly.
Jul 13, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Well I got a new psp with a 2 gb memory stick produo with a Memory Stick Duo Adaptor. Well this is the problem: When I insert the adaptor with the memory stick inside my computer won't show any files it...
Put the card back in the computer and format it using FAT (not NTFS) format. In the format menu, you'll see the file system pull down option, choose FAT and try and format it again.
Thanks Mark
Jun 24, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
Hi, I can view the pictures of a memory stick on my camera, but when I put it in the sleeve and insert it in the computer, the computer can not read the disk. I have also used the USB wires hooking the...
possibility: the memory card is not formatted in a way that your computer to recognize it.
give this a try...
*format the memory card first (FAT32 or NTFS) using your computer
*put the memory card back to your cam, then click away
*then try to read it again in the pc.
Jun 22, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Problem with the sandisk 4gb micro sd card. my computer cant format it. Y
some comp cant read the card a cheap fix is go to radio shack and get a reader/writer card its a usb connnection and should work for it did for me even my printer couldn t read my 4 gb
Aug 10, 2009 | SanDisk 4GB microSD High Capacity Memory...
Electronics - Others Logo
114 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
