Apple iPod nano 3rd Generation Logo
Question about Apple iPod nano 3rd Generation
My ligh blue 8Gb 3rd generation ipod nano will not resond !
My ligh blue 8Gb 3rd generation ipod nano will not respond to anything. it is frozen on the time and battery display and the backlight is still on, However, the battery is not dying after having been on for hours. it has not been dropped or exposed to any moisture. it was working per usual then it froze and when i put in the USB cord to charge it it doesnt respond to that either. It doesnt even turn off.
Posted by sweetpealove on
Anonymous
    President:
  • 1,285 Answers
Once the battery dies completely...plug it to pc (itunes should pop up also) , when itunes comes up check for update of ipod it might need it....this shall stop the ipod from freezing up...have fun and enjoy
Posted on Jul 10, 2009
2helpful
My nano 8gb has frozen and shows connected eject
You just need to reset it, hold down the middle button and the "Menu" button for about 7-8 seconds or until you see the Apple logo.
Hope this helps!
3helpful
My 3rd gen. ipod nano is frozen
just press the menu and power botton at the same time. that reset your Ipod
2helpful
I have the same problem!!
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
5helpful
Ipod nano 8GB 3rd generation FROZEN!
Try resetting the ipod while its connected to the computer by holding both the menu and center button at the same time for 6-10 seconds until you see an apple appear on the screen. You may need to repeat the reset. If this fails your looking at a hardware issue most likely. Good Luck.
1helpful
Try this: Press and hold the wake/sleep button and the home button simultaneously for ten seconds and the apple logo should appear on the screen. Release the buttons and it should work like normal. Hope this helps.
3helpful
You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
hi,
Firstly, don't worry about your ipod, i had the exact same problem with mine and with 3 of my friends here in athens!
Just leave it frozen untill it drains out of battery,
then try plugging it on your pc and leave it plugged for a while,
after doing that try to open it.
NOTE: my ipod opened after this step and worked properly.
If the ipod still don't works you can do the same as my sister did.
Take the ipod to your sales man and get a software update or replace it (if you are still in guarantee period)
Hope i helped,
Looking forward to hearing from you for further assistance!
2answers
Don't respond to them. It isn't legitimate. There selling something and I wish they would cancel his account.
It could be the battery. Do you have an Apple store nearby. You might want to have him look at it. They will do that for no charge.
Best Buy can look at them as well if you don't want to go back to Apple.
363helpful
6answers
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Top Apple Audio Players & Recorders Experts
woodzowl307
Marvin
Marvin
Muzahura Frank
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
