Question about HP Business InkJet 2800 Printer
Appearing dots on printer screen
When i connect power cable in HP business inkjet 2800 its didnt work but moving dots on printer screen.....
Posted by atif4000_sa on
  • atif4000_sa Jun 07, 2009
    Thanks Bro for your reply, i just tried but its same thing, even i tried without cartdriges and its gaving same problem, no any movement just appearing Dots on printer screen...
    can i reset this Printer??
    Pls bro Help Me...
Anonymous
    New Friend:
  • 5 Answers
I have had the same issue, discovered that a 680Uf 6.3v capacitor was blown on the PC board. Replaced the $.14 part, the world is happy once again.
Posted on Sep 01, 2010
  • 3 more comments
  • lmphashby123 Apr 03, 2011
    Can you give me the step by step instruction with pictures if possible of removing the cover to get to the PC board. I have discovered two screws and nothing is coming off??
    please email [email protected]
  • print_mures
    print_mures Jan 10, 2013
    I have the same problem, please e-mail to me the solutions step by step instruction with pictures if possible of removing the cover to get to the PC board. E-mail me: [email protected]
  • marc nadal Sep 24, 2013
    I have the same problem and I don't know how to solve it. Please, can you send me the step by step instruction with pictures if possible of removing the cover to get to the PC board. A lot of thanks!! mail me: [email protected]
  • Rui DeSousa
    Rui DeSousa Nov 03, 2013
    I have the same problem with my hpinkjet 2800. Were you able to fix the proble,or receive the instructions. If affective the solution would someone let me know how they solved it and on which side of the printer it is
  • Rui DeSousa
    please email me at [email protected]
Anonymous
  • 4 Answers
From HP:
To cold reset the printer, with only the power cable connected.
By doing so, the printer settings will default to factory settings. Please note that after a cold reset the printer settings will default to factory settings and you may have to re-configure all the settings.
Press and hold the Return and Select buttons, then press Power button to turn on the printer.
Posted on Jul 20, 2009
rommel dadulla
  • 822 Answers
Pls check the cartdriges and clean head first. and plug it, power on again your printer. try to print.
Posted on Jun 07, 2009
    that what a useles sugguestiong romsky79!!!! one has nothing to do with the other!
Inkjet 2800 firmware
Setup & Install for HP Business Inkjet 2800 Printer series:
http://bit.ly/1h83Ey5
Apr 19, 2014 | HP Business InkJet 2800 Printer
Hp 2800 printer will not boot after multiple attempts at cycling the power all that happens is the green light and scrolling dots on the display screen
In all likelyhood, a capacitor on the main pc board had blown, they problem caps are TEAPO 6.3v 680uf. Look at the caps and see if any of the tops of bulged up. If so, replace the caps (about .14 each). The caps control voltage to the actuators, without which, the printer's OS never gets past initialization.
Jun 27, 2010 | HP Business InkJet 2800 Printer
HP Business Inkjet 2800 firmware PMR2006A
Unfortunately the page you are trying to reach is not a valid page. As an HP tech I searched internal for a firmware update on that model and there isnt one available.
Jun 05, 2010 | HP Business InkJet 2800 Printer
When power applied to HP2800 PLC6 green light illuminates and dotted line draws across LCD screen. no other response. no buttons work. Is this abad one?
Most probably the power supply has gone bad , and caused damage to the main board.
I don’t think this is worth the repair costs. Still working on it.
Nov 19, 2009 | HP Business InkJet 2800 Printer
Reset hp2800
Hard Reset
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds then replug the power cable to the wall out let and then to the printer.
Power Drain
Remove the cartridges from the printer then unplug the power cable from the back of the printer and from the walljack wait for 30 seconds now press and hold the power button on the printer and replug the power cable to the wall out let and then to the printer after the power cable is connected you can let go off the power button..
Aug 11, 2009 | HP Business InkJet 2800 Printer
HP 2800 BUSINESS INKJET PRINTING VERTICAL LINES
Try This:
cold reset on the printer with only the power cable connected. By doing so, the printer settings will default to factory settings. Please note that after a cold reset the printer settings will default to factory settings and you may have to re-configure all the settings.
Feb 10, 2009 | HP Business InkJet 2800 Printer
Cannot connect using Appletalk protocol
Given that this issue is three years old, and AppleTalk protocol is no longer even supported, it probably should be laid to rest.
Oct 17, 2007 | HP Business InkJet 2800 Printer
HP Business InkJet 2800 Printer Logo
1,428 people viewed this question
Ekse
Thomas F. Schneider
