Maytag msd2655HE side by side... the freezer is not keeping things frozen anymore. And there's a noise, possible the fan or compressor, about every few minutes. the fridge seems to be cooling okay, just not the freezer. lights still work in freezer, water working, just not cooling properly.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Hi, There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Sometimes that happens just before the solenoid that opens your dispenser fails. As the coil weakens they tend to vibrate or buzz. I will search for the part number for your model MSD2655HE Be right back, Sea Breeze
Without actually putting gauges on the system to see what is really going on, I would say that your compressor has failed. There is a good chance that it is something inside that has broken. Turning it off and back on will give it another life sometimes but like youexperienced it is usually short lived.
I assume that you have checked that the condenser fan is running underneath the fridge. Also that the condenser coils are not completely plugged with dirt. These things can also make your firdge od wierd things...
This should give you a couple of things to checkout, but I fear that the compressor is bad and you will need to replace it or get a new refrigerator. If you choose to replace the compressor get a full price quote before the work is done, as it may not be worth doing if you have an older refrigerator.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
The defrost coil may be bad. It's real tough to get at, you have to remove the cover over the freezer coils. First make sure it's not just the defrost timer. Check Repairclinic.com for parts and help.
Try this, I went to the freezer side pulled the inside back panel (had to defrost it to get it out) and it was completely frozen over. It was not not operating properly because the cooling coils would not allow the fan to pull air through them to cool the refrigerator side. I completely defrosted the coils and turned the refrigerator back on, it worked fine. I then ordered a new adaptive defrost assembly (this is the thing that prevents the ice buildup) since ours was apparently not working properly. I used a fan too speed up the defrost process, because i had to take all the frozen food out and put it in a cooler to get to the back panel. After you take out the racks and food you only need to remove two screws that have a 1/4' head. good luck.
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
