The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
L100 has a tension spring on them it may have broke or came off. If i can help any further you may call me and i will help you. I worked for john deere for several years. (831)578-4034 thanks wade
