Tablets & eReaders Logo
Question about Itronix Duo-Touch IX325 Tablet PC
ITouch Just Cant Go Back To Home Screen
I was Surfing A Sports Website With My I Touch. After Surfing , I Tried To press The Home Button To Get Back And Play Some Games. But The Home Button Doesn't Work It Just Pop Up A Screen Asking Me If I Would Like To play A Song. I Tried To Shut Down My I Touch But It Just Would Not Work. Please Help!!!!!!!!!!!!!!!!!!!!!!
Posted by runey_777 on
Anonymous
  • 1,305 Answers
Press both the the on/off button and the selector button at the same time. that will reset you itouch..
then I'd avoid that website.
K
Posted on Jun 07, 2009
Access to home page on Kindle touch
Wake the Kindle by pressing the button on the bottom edge of the device next to the USB jack. Then after the unit wakes up, navigate to the home screen by pressing the button centrally located on the front of the Kindle below the screen. (I doesn't look like a button, it resembles a grille and consists of 4 black parallel lines.) The home page will pop into view unless you were already there upon waking up.
1helpful
2answers
My touch screen dosent work when i press it i have a go tab tablet
If it doesn't respond to the touch when you tap it, at any place at all, the you need a new digitizer.
I have a tablet model number cmp743d my kids locked me out of my lock pattern and now it asks google name and password and I am locked out there too. Tried to reset with no luck. How can I fix it or do I...
1. Turn off your Craig CMP743d tablet by holding the Power button and selecting Power Off. 2. Simultaneously, hold the Back button and On button for 8 seconds. 3. When the android icon is seen already, press the Back button. 4. In the menu, just select the wipe/factory reset by pressing the Home button, followed by the pressing the Back button. 5. A new screen will appear. Select "Yes, delete all user data", then press Back button. 6. on the next screen, select "Reboot System Now" by pressing the Back button. 7. Just wait for your tablet to reboot.
Troubleshooting innotab screen
have you tried calibrating the screen? You can do this by pressing the Home Button, question mark, and volume up button all at the same time. Turn the toy on without letting go of the other three buttons until you see the Touch Calibration Screen. If this does not help, then I suggest you call Vtech. Contach info is available at www.vtechkids.com if you no longer have the manual.
1helpful
I have forgotten my pin code for my supersonic SC-74MID tablet. How do I reset it?
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
Forgot password to craig wireless touch tablet now i cant use it
This works with devices having physical home button:- 1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
Reset factory setting from safemode menu,
check the video in my blog lol
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
4helpful
3answers
Can not unlock my coby tablet
it seems like that your tablet's touchscreen panel has a defect, to get the full functionality of the touchscreen panel it should be replaced...
5helpful
2answers
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Power the unit off (holding power buttom) and selecting Power off, then hold simultaneusly back button and on buttom 8 seconds,the android icon appear press back buttom, in the menu select wipe data/factory reset pressin home buttom and then press back buttom, in the next screen select "yes delete all user data" pressig back buttom, and in the nex screen select "reboot system now" with the back buttom and wait. IT WORK FOR MY TABLET
Top Itronix Tablets & eReaders Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you an Itronix Tablet and eReader Expert? Answer questions, earn points and help others
