Question about Water Heaters
No hot water...where is the reset button on the 81vh40d hot water heater by Rheem
Posted by singharmony on
gary miller
  • 332 Answers
The reset is under the top cover, take the screws out and there will be a plastic sheild pull it off DO NOT TOUCH ANY WIRES push the reset button you should here it come on,, if there is any water present do not turn it on but find the source of water and fix or replace the water heater
Posted on Jun 07, 2009
What is causing electric tankless hot water heater to be needing red button reset often?
PDF]Tankless Electric (RTE) Troubleshooting - Rheem
www.rheem.com/docs/FetchDocument.aspx?ID=87d15e35-5adf-4e9f...
Tankless Electric (RTE) Troubleshooting. Technical Competence .... For four chamber units (RTE18 & 27) go to paragraph 4T. 9. Conduct OHMS resistance ...
Rheem RTE 27 Series ' Use and Care Manual
https://www.manualowl.com/m/Rheem/RTE-27-Series/Manual/296033
Rheem RTE 27 Series ' Use and Care Manual - Page 1. Use & Care Manual Electric Tankless With Installation Instructions for the Installer Water Heaters The ...
Sep 06, 2015 | Rheem RTE 27 Tankless Electric Water...
Brand new electric hot water heater doesn't get water hot
Call Rheem
Reset breaker fully off and then fully on.
Test for 240 Volt across top two screws on upper thermostat
Press reset button located on upper thermostat
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 01, 2014 | Rheem Water Heaters
Home water heater no hot water
Electric water heater?
Open top cover and push in reset button.
Check circuit breaker.
Gas water heater?
Use mirror and peer upward through sight glass to see if you have pilot flame, and that flame is clear blue.
Clean air intake.
Change thermocouple.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Tankless gas?
Call service technician.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 29, 2012 | Rheem Water Heaters
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 26, 2011 | Rheem MR105245 Marathon Electric Water...
Elctrical wiring of the thermostat Rheem hot water system
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I need to know where the reset buttons are located on the 30gal model 71-305 Rheem hot water heater. Help I'm not getting hot water so I'm trying to start with what may be a simple solution.
Shut off all power to water heater at breaker panel,remove side cover where thermostat is located. Test that there is no voltage at connections, with meter, to be 100% sure you shut off correct breaker. Thermostat should have a red button in middle to depress to reset if it's tripped.
Oct 23, 2010 | Rheem Water Heaters
Water Heaters Logo
292 people viewed this question
Top Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Water Heater Expert? Answer questions, earn points and help others
