Question about Sharp AR-275 Copier
My AR 275
GOOD MORNING I BOUGHT AR 275 BUT I DONT HAVE THE USER MANUAL MORESO ALL THE SIGNALS ARE WRITTEN IN GERMAN KOPIE, DRUCKEN, BELICHTUNG E.T.C AND IT IS SHOWING ME A CAUTION SIGN WHEN I SWITCH IT ALTHOUGH ONE OF THE DOORS IS SPOILT SO IT IS SHOWING SIGNS OF A SPOILT DOOR PLS I WOULD APPRECIATE IT IF I COULD BE SENT A USER MANUAL WITH PICTURES POINTING TO WHAT I HAVE TO DO
Posted by MR JOHNSON on
CheckitRight
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,363 Answers
Here you go :
http://www.sharpusa.com/files/cop_man_ar235_75.pdf
Now you can re-label everything in plain old English.
Posted on Oct 26, 2007
Sehr geehrete Damen und Herren, how can i get an Manual (Bedienungsanleitung) for Programm ''Duplicat Cleaner v.1.4'' in german Language ? Herzlichen Dank und freundliche Grüße Reinhard Neubert
Hallo, habe mit google leider auch nichts gefunden. Frag aber ruhig mal die Profi-Rechercheure von http://manualfox.com/de - die finden so etwas normalerweise ganz schnell.
Gruss
Passy
Jan 27, 2010 | Computers & Internet
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Cannot clear stored fax data?
look in the fax manual there should be a section on that
If you have no manual call the company where the fax machine was mad.
May 13, 2009 | Sharp AR-275 Copier
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
I dont understand my car
Try this link, should be the right one for your car.
Hope this helps,
Mark.
Nov 02, 2008 | 1997 Mazda 626
Sharp AR-275 Copier Logo
77 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
