Question about Microsoft Xbox 360 Console
Resetting How do u reset the 360 system? should I take the Hard drive out to keep the memory? The 360 makes a mmmmmmmmmmmmmmm sound and keeps saying open tray when I put any kind of disc in. Austin
  • Anonymous Oct 26, 2007
    To clean the laser lens do u need to take the 360 apart?
    Austin
Lyle Siemens
  • 328 Answers
Resetting: http://news.teamxbox.com/xbox/11131/Xbox-360-Cache-Clear-Code-Revealed/
You should be able to open the cd tray and then unplug the system so it stays open. Grab a flashlight and you can see the laser lens. You may need something longer than a Q-tip but should be cotton at least. Be very carfull not to push or try to move the lens.
Posted on Oct 26, 2007
Haier L32A2120 flat panel Keeps channeling and does not stop when using remote
Sounds like main system control memory IC is faulty. Anyway, do a reset to this set and check. It it too do not help, replace the memory IC
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 23, 2014 | Haier L32d1120 32" 720p Lcd Tv - Hdtv Usb...
Have hatachi tv 2 years old and can install all channels and all ok but then suddenly can loose sound and screen says *not in service* so I have to retune and install channels again but it keeps doing...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 31, 2018 | Televison & Video
How do you reset the family password on the xbox 360
1. On the 360 dashboard, scroll over to the "System" tab.
2. On the System tab, click "Console Settings".
3. Scroll down in console settings and click "System Info".
4. When the system info box comes up type in this sequence:
LT RT X Y LB RB Y "Left Stick in" (press it in) Y Y
A box should come up and say, "Would you like to reset the console to the factory defaults?"
Click Reset and you're done!
If this doesn't work, and that's highly unlikely, call Microsoft at 1-800-4MY-XBOX (U.S.). Provide them with your registration info and they will tell you how to reset the console. If you would like to keep your game memory take out your hard drive and follow directions above. Hope this helps.
May 12, 2012 | Microsoft Video Game Consoles & Games
My nephew's original xbox will not turn on it just flashes green and orange around the power button
If your system has had an internal system error (three lights) and is now having issues recognizing controllers, remotes, and/or personal music player's, the only currently know solution is to rerun initial setup.
Rerun initial setup
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the "Initial Setup" option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
Resetting to factory defaults / resetting parental locks (unconfirmed)
This was posted on the xbox-scene forums and might work only with older versions of Xbox 360 dashboard.
Press the following key combination
  • Left Trigger, Right Trigger, X, Y, Left Bumper, Right Bumper, Up, Left Bumper, Left Bumper, X
This should give you a dialogue asking whether or not you want to reset your system to factory default settings.
Reset Xbox 360 video settings
While the Xbox 360 is starting up, hold Y and Right trigger. This will cause the system to reboot and reset the video settings.
Nov 21, 2010 | Microsoft Xbox Console
MY XBOX 360 KEEP SAYIN E 67
E67:
Hard Drive Error - Hard drive timed out during reset: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
Al
Jul 30, 2010 | Microsoft Xbox 360 Console
Play dvds on my xbox it says that my memory card is not in
Hmm that is odd but make sure the hard drive is firmly in its spot otherwise the console might keep doing that to ya. and it says memory unit it might be referring to the the memory units in front of the 360 so make sure you don't have anything in those slots that might be loose.
Jul 01, 2009 | Microsoft Xbox 360 Console
Password to delete or change parental code
Turn off your 360 Unit
Remove all memory devices
restart 360 Unit
go to system blade > Console Settings > System Info
press
left trigger, right trigger, x, y, left bumper, right bumper, up, left bumper, left bumper, x.
THEN immediately afterwards, press DOWN, Y, UP, DOWN
This should bring up a menu
Reset System Settings
Resetting your system settings
will return all console settings to
factory defaults. Do you want to
reset to factory defaults?
Yes, reset settings
No, don't reset settings
select to reset settings
your screen should go blank for about 2 seconds
then the language blade should appear that lists several different languages,
select your preferred language
then a blade that says "Xbox 360 Storage Device" should appear
With the options of,
Done
Continue without one
select to Continue without a profile
Then an Initial Setup Complete screen should appear
with the options of,
Family Settings
High Definition Settings
Xbox Dashboard
select Xbox Dashboard
Now turn the system off, insert the Memory Unit or Hard Drive, and turn the system back on.
No more Parental Control lock.
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 wont play the games but will play cds and dvds !!!!
Mocrosoft only entended the warranty on the "ring of death" issue which was hardware related to overheating.  They did not extend the warranty to any other issues.  DVD/CD emulators and the games emulators are handled by different software.
You can try a factory reset of the console...
Before trying this, it's highly recommend that you remove all hard drive and memory cards. Once you've removed all hard drives and memory cards, navigate to the systems tab in the main menu and select the “Initial Setup” option. Once you select the option, it will ask you if want to run the initial setup that occurred when you first started your console. Say yes and it will do its thing. When it asks for a memory card/hard drive, just decline and it should be done. You should see the default dashboard screen as confirmation that it did, in fact, rerun initial setup.
This might work only with older versions of Xbox 360 dashboard.
If none of this works contact Microsoft and see if the console is still under warranty.  If not they will repair it for usually 99.00
Dec 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
268 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
