Question about Palm Zire 31 Handheld
For some reason my Zire 31 won't sync with my palm desktop anymore. I have Windows 7, and successfully downloaded and installed the driver for it. My Zire battery went dead, it is not recharged, but I can't sync to my desktop to retrieve my data from the computer.
5 Related Answers
Anonymous
SOURCE: Palm frozen - Won't Move
o at the back of ur palm is a reset button just press it and it should be fixed
Posted on Feb 09, 2007
Anonymous
  • 33 Answers
SOURCE: How do I make a hard reset on my Palm Zire 31 PDA?
There is a reset pin hole on the back of the unit; Hold the power button and push the reset button in the hole with a paperclip. All memory should now be erased.
Posted on Apr 01, 2008
Anonymous
SOURCE: palm zire 31 screen is fading. I cant read the words anymore
temporary fix: adjust the contrast
Posted on Aug 04, 2008
Anonymous
  • 3 Answers
SOURCE: Palm Zire 31 Synch stopped working
ideas:
Restart your computer,
Try a different data cable,
And last resort:
Give up on it.
(If you do give up, send it to me i need a new screen.)
Posted on Oct 19, 2008
wardyorgason
  • 47 Answers
SOURCE: It worked fine for a few years then my computer
Reinstall Palm Desktop and or update it.
Posted on Feb 13, 2010
How to sync palm data with Itouch? I have all my contacts & calendar on my Palm Zire. How can I get the same data over to my I touch in a Windows XP environment ?
You can sync to Outlook on the PC and then get the Outlook data onto the iTouch. If you have a newer PDA, It's install CD has a Sync options menu item where you can switch between Palm Desktop and Outlook. If you no longer have the original install CD or have an older device Pocket, Copy from Chapura.com It will move the Palm Desktop records to Outlook.
6helpful
No Windows 7 driver for Palm Zire 21
Wait till one is provided by the manufacturer. Palm Desktop: Windows 7 compatibility Palm's synchronization software, Palm Desktop 6.2, was designed for 32-bit versions of Windows XP and Windows Vista. Palm has not done thorough testing with the broad range of third-party equipment running Windows 7 and therefore can't provide assurances about compatibility.
New computer running Vista won't recognize Zire 31-no driver?
Have you installed PalmDesktop to your new computer yet?
There is no Windows driver for the Zire 31, but you will need Palm Desktop before you can sync.
I still have a Zire 31 in a box in the garage, and I'm happy to dig things off of the CD if you need anything, just use "add comment" in the top right corner there.
2helpful
2answers
How to HotSync Clie' and Palm Zire
install it on another computer buy her a computer
How do I NOT HotSync with Outlook?
Insert the installation CD and select Change your synchronization method. If that doesn't work, or the option is not available, in Windows, click Start>Run then D:\English\PostInstall\OutlookSwitcher.exe /palm (where D: is your CD drive AND your install CD is inserted; also check to make sure the file is at that location).
Palm Zire 31 Handheld Logo
Top Palm Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
