Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Why won't my mitsubishi wd 65733 tv turn on and the lamp light keeps flashing?
5 Related Answers
phil_frye
Philip Frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
Anonymous
  • 21 Answers
SOURCE: I have a Mitsubishi WD-52725 projection TV .I
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Posted on Jan 20, 2010
Anonymous
  • 117 Answers
SOURCE: wd-65733 Mitsubishi Tv green blinking
You need a new projector bulb. Google up your model and buy the best warranteed one you cAN FIND. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!
Posted on Aug 13, 2010
ladywinn
ladywinn
  • 5138 Answers
SOURCE: I just replaced the blub on a Mitsubishi 65 inch
Ballast Board 1-800-638-3328
Posted on Oct 21, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: I have a Mitsubishi WD 65733 TV. Red lamp light comes on after picture appears on screen.
Check this possible answer I provided and it worked for another similar set:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on May 23, 2012
Mitsubishi WD-65733 Red light on Replaced lamp twice
I'd just replace my lamp just three days ago and the problem still
exsist
Nov 10, 2013 | Mitsubishi WD-65733 65" HDTV
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
I just replaced my lamp, but now the tv wont turn on, all i get is the lamp light blinkung yellow
You need to reset the lamp timer. Should be in the manual or else download the PDF from the mitsubishi website
Aug 12, 2010 | Mitsubishi WD-65733 65" HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Blessings,
A/V Media Guy
Nov 20, 2009 | Mitsubishi WD-65733 65" HDTV
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
