check to see if the brake lights come on when you press brake pedal. if they don't it is stuck in park because your brake light switch doesn't work and the swich also tells the shifter lock to unlock so you can move shifter. so If no brake lights fix brake light switch and that will fix it. the switch is located at the top of brake pedal
Seems verry likly that the lock switch has stuck in the lock position and will most likly need to be replaced. Unless you are able to remove and spray with a contact cleaner
There is a neutral safety switch on cars with automatic transmissions which operates the reverse lights, and a reverse switch on manual transmission models. You need to check voltage output on which version you have.
Hi Your door latch is bad and this is very easy to replace, First make sure the power is turned off , then removee the screws all around the door The door swich has a few wires going to it, unplug them and mark them , you will see small micro switches on this door latch they will need to be removed and put onto the new door switch , you can purchast a new door switch from this place i have gotten very good service from them , http://www.appliancepartspros.com/Appliance-Parts/whirlpool-dishwasher-door-latch-item-number-ap4481280.aspx this place has almost every brand name and they ship same day , good luck and this should be an easy fix Guy [email protected]
1 check the supply wire to swich change if it is not ok
2 chek the swich change if it is not ok
3 if it is automatic check microswiches(one where ground coffee comes out and other below doser) clean from coffee upper swich and try. it block sometime from ground coffee
4 check the windings of electromotor givegrinder for if it is not ok
5 check condensator change if it is not ok
6 try to spin the burrs by hand, check if they are not blocked. change bearings if it is not ok
if you need to change bearings you need advice how to open the motor.
If you have the standard pull out push in switch, reach underneath the dash and push in on the small button on the switch (look at the new one and you will see it...looks like a small rivet head with a spring under it) While holding the button in, pull the knob and shaft out, then just remove the nut around the switch extension and remove/unplug the switch. Once the new one is in, just push the knob back into the switch and it will lock in.
The fork lock is part of the ignition switch assembly. You have to remove the swich (tricky little button under the switch with the switch in accessory position I think) after which you remove that lower inner fairing schroud that has your rear speaker, cruise, accessory, and passing lamp switches. then remove the lock. The lock has a harness that needs to be unplugged. I'm uncertian if the outer fairing needs to be removed to unplug. you will know when you go to unplug it.
