With just battery or only AC connected same fault No start on power up only a flashing DC in LED with error code I believe of HEX 27 Before this problem everything worked well
SOURCE: my laptop hangs everytime i
the power supply is defective replace it, because it does not provide the reqired AMPERAGE to your laptop STOP USING IT it could dammage the laptop... or it could be the battery for a sure test boot the laptop using just the power supply remove the battery (ONLY ONCE JUST FOR A TEST) if all is good (with just the powersupply) you could try a new battery with the power supply TOGETHER to confirm the problem
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
