Philips 150S4FB 15" LCD Monitor Logo
A
Anonymous Posted on Feb 06, 2014
Philips screen is showing - monitor controls locked
3 Related Answers
Anonymous
  • 62 Answers
  • Posted on Sep 12, 2009
SOURCE: Control menu locked
I am not able to find the solution but I have got the very same problem with my HCL LCD monitor.
Threetech Solutions
  • 634 Answers
  • Posted on Oct 31, 2009
SOURCE: my philips monitor shows your
Is there button of keyboard, mouse not probably work,if it was ,that is the problem of mouse or keyboard or CPU ,If it not you want to try by going into control panel and will found that some your file is missing,then try to install.
Anonymous
  • Posted on Sep 03, 2011
SOURCE: philips monitor 107e 17" monitor
sir I Have Philips 107c5. control menu lucked
1helpful
Have screen message saying monitor controls locked what to do to fix
Conrad, your manual should tell how to unlock.
If you have no manual google search for one.
To show your appreciation press the helpful button and follow me on fixya for more tips and info
tip
Philips LCD monitor Loc-Unlock instructions
Question My monitor shows the message: OSD MAIN CONTROLS LOCKED. What can be the cause of this message? Answer To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC
http://www.p4c.philips.com
on Apr 27, 2010 • Computers & Internet
2answers
Philips monitor osd locked
you have to carefully force open the clipped back case of the monitor and disconnect completely the cable to the front control buttons, then the monitor works fine though no adjustments can be made
3helpful
Smart image on philips lcd on screen
Dont Buy Philips monitor. I have 20 pcs monitor and after one year half of them had malfunction. smartimage with vertical lines back and forth and that all controls are locked that cant be unlock by holding any button. Some had white screen when Resolution exceed 1024X768 (when 1280X768) after a year.
Maybe they program it to malfunction after a year. My CDR king and AOC monitor had no problem 2yrs to present date.
Philips monitor are garbage
Sorry for bad english.
10helpful
2answers
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
1helpful
My philips monitor shows your "control menu is locked"...how to fix this problem....
3helpful
Control menu locked
4helpful
Osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
42helpful
5answers
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Top Philips Computers & Internet Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
