HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
Why can't I get my HP s3100n to run USB 2.0?
I have a HP s3100n computer. When I plug in a USB device, I get a message that "This device would run faster if you plugged it into a USB 2.0 port. Then is shows all my USB ports. None of them have USB 2.0, even though my computer says I have some. I've tried to download and install a generic "USB 2.0 Standard Enhanced Driver", but when I attempt to upgrade the driver for either the USB "Standard Enhanced PCI to USB Host Controller", I recieve the message "Windows has already installed the best Driver for this device. Does anyone know how I can change my USB 1.O port to a USB 2.0 port?
Posted by Billy Guy on
charles spear
    New Friend:
  • 4 Answers
I was window shopping at Rite Aide and I saw these adapters that you plug into your USB ports and their out puts were 2.0 and others I think it was 12.00 USD
Posted on Feb 06, 2014
2 Related Answers
Anonymous
  • 59 Answers
SOURCE: Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Posted on Jan 01, 2009
Anonymous
SOURCE: when i plug my akai mpk49 into my usb port it asks
me gonna hack a audition bot did not now how to hack?
Posted on May 19, 2009
Looking for any complaints regarding the motherboard for the HP Slimline s3100n.
HERE is a whole site of listed complaints regarding the computer you listed. HP Slimline s3100n. I hope this helps and is what you were looking for.
7answers
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Freezing upon boot
restart and tap F8 key, if loads to repair your computer/Advanced boot option, select safe mode using the down arrow key and log in to your account, create a backup of all the data on a removable storage device.
Insert System disk and run a system recovery to the original fcty setting, if backup done, restore from the removable storage device.
3answers
Slimline s3100n keeps shuttubg down
scan for viruses. maybe it is infected. if still, do the recovery options for hp.
2helpful
Error while communicating with scanner message
Smile...well this is due to a default setting in windows which u need to change.
1. leave the device plugged to the USB & power it
2. Go to device manager \ expand (+) universal serial bus controllers
3. Right-click \ properties \ usb root hub \Power management tab \ uncheck box (allow the computer to switch off the device)
Restart! Don't forget to vote me dear!
2answers
This usb device can perform faster if you connect it to a hi speed usb 2.0 port. I have an hp pivilion dv 6000, and according to the specs, I have usb 2.0, but I get this message every time I plug my flash...
This is just an error message. Yes, your HP Pavillion has USB 2.0, but there's a possibility that your USB flash drive has USB 1.1 specs.
If the flash drive has USB 1.1 specs, you would still get the same message. Again, this is just a message because USB 2.0 is backwards compatible with USB 1.1.
Have a great day!
2answers
Pop up message says that I have a USB device that is not recogniz
Do you have anything like a printer or scanner or an external USB drive connected to the computer. If yes, then remove it. If not let me know.
1helpful
Bought HP S20 New in box on Ebay......installed software......powered up and linked USB......message "communication with scanner lost" cannot rectify
I use an older USB Powered Hub between my computer and the S20 scanner, a Belkin I found at a garage sale for $2 works fine. It is only rated for USB 1.1. The S20 is a USB 1.1 device. My computer was "too fast" with its USB 2.0 ports and it looks like I needed to "slow it down". There is no way it will worked plugged directly into the computer, but plugged into the hub, and then the hub plugged into the computer, it is very reliable.
Windows XP had nothing to do with it, from what I can see. I had Windows XP on a previous computer with only USB 1.1, and ran into the problem when I got a computer with USB 2.0 ports.
Usb ports not working
hi,
What device are you trying to connect? was there an error message when you plug in the usb device. try booting up your computer to safe mode with networking.
1. Restart the computer
2. Keep on tapping F8 when you have the HP logo screen, using the down/up arrow of the keyboard choose safe mode with networking. if the device still not working then it could be a problem with the USB driver. You may try restoring your computer back to the working time using system restore. Just go to start then Accessories - System tools- system restore.Restore your computer to a working date.
Keep me posted.
Thanks.
When i connect my hard drive to my laptop the baloon comes up saying that usb device is unrecognized.
SYMPTOMS: loadTOCNode(1, 'symptoms'When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
To work around this issue, use one of the following methods:
Method 1 loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2 loadTOCNode(2, 'workaround');After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 4 loadTOCNode(2, 'workaround'); Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties. b. Click the Power Management tab. c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.-------------------------------------------
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Top HP Computers & Internet Experts
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
