I PUT TWO NEW PADS IN THIS YEAR , THE UNIT IS @ TWO YEARS OLD
SOURCE: There is no water going
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
