Question about LG LSC26905TT Side by Side Refrigerator
Ice maker The refrigerator works fine with the exception of the ice maker, which is not making ice.
Posted by Lampho3 on
  • 2 more comments
  • Lampho3 Oct 31, 2007
    Although the water dispenser works, it appears that the water is not activating for the ice maker on my LSC26905SB LG side by side refrigerator.  Can you suggest what might be causing the problem
  • bronwmccrak Jun 30, 2008
    No ice - water is working fine. Removed tube, it is not frozen. What else might be the problem?
  • caupo Jan 08, 2009
    the fridge works fine, the water is cold but no ice cubes?
    Can you help?
    Thanls,
    Roland
  • bevo2009 Mar 05, 2009
    Even if the temperature in the freezer is below freezing, the ice machine will not function if the temperature is not around 15-20 degrees. My ice maker stopped dumping the ice, even though it was filling properly, and the water would eventually freeze. My problem is related to excessive frost accumulation on the back wall, which in turn, shut down the fan, which in turn, raised the temperature in the freezer. Once I defrosted the freezer manually, the ice maker started to work again, until the frost buildup occurred again. I recommend placing a thermometer in the freezer to get a reading.
Anonymous
I believe the tube that pours water into the icemaker tray is clogged with frozen water and can not fill the tray and your fridge can not make ice. You have to unplug your fridge and let the tube to defrost. It is a long tube (about 1.5 foot) and using a blow dryer may not do the job. You can unscrew the the gray plastic cover at the back of the fridge and pull out the tube and let it defrost and then put it back.
Posted on Apr 26, 2008
Anonymous
I just bought an LSC26905TT and it was used there are three electric valves where the water goes into the fridge on the back the first valve on the bottom for some reason was running directly into the door water dispenser which tells me it was bypassing the ice features. One tell-tale symptom of this is that once in a while you'll notice it squirt water as it is on the master valve which opens when each of the other valves open. So I swapped the tube by pulling the clip and pushing the sleeve up pulling the tube out and swapping it with one of like size (the large tube coming up the back to the filter) there are three ports for tubing the one closest to you should go to the large filter (blue) tube. the one on the back right should be a small white tube going straight up to the back of the freezer. and the one on the back right should be a large blue tube going under the fridge towards the front (door) which is for the water dispenser. the middle one is your supply (small blue tube) the one that comes back from the filter. If the "wiring" of the hoses is correct then the back left solenoid is either stuck or broken. you may have to replace both rear solenoids, it looks to be a simple job and part may not be too expensive either. always remember to pull the sleeves back down the tube after you've shoved it in the hole and replace the black clips so they cannot fall out.
Posted on Jul 02, 2008
Anonymous
Water does not appear to be entering ice maker unit.
Posted on Jan 10, 2008
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a hotpoint refrigerator freezer that works fine except i am having issues with the ice maker. The tube carrying the water to the ice maker goes through a support cup. Water has started freezing in...
Make sure tube is pushed all the way into back wall tight.Then make sure tube angles downward so water completely drains. This is a goofy GE problem.
Aug 16, 2011 | GE Refrigerators
Ice maker quits working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
poptypty
May 23, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
[email protected]
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
LG LSC26905TT Side by Side Refrigerator Logo
625 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
