It has power to the heating switch and a new element(I know there is power to the switch due to the light being on). There are no loose wires I can see without completely disassembling and there doesnt appear to be any corrosion or buildup on any electrical surface. Due to the nature of the machine(head spins constantly when master switch is on) I can't determine whether power is reaching the element itself. Not sure where to go from here. Also have a Floss Boss 3024 with the same problem.
The most common cause to a not heating problem is that the heat ribbon is installed wrong. If it was recently replaced, the 2 wire terminals need to be connected to the 2 different buss strips in the head. If both are attached to the same one, then nothing happens.
2. If this is not the problem, then inspect the brushes and slip rings in the lower spinner head. Remove the access covers and see that the brushes are tight against a shiny smooth Brass slip ring. it is common for brushes to get stuck in holders and stop contacting rings.
3.last item is the heat control.
These are pretty advanced repairs, and should be attempted by a service technician with assistance from a Gold Medal service person.
