Question about KitchenAid KHB300 Handheld Blender
Hi, I am able to replace the glass jug that I broke with a new one, but can you tell me how to undo the blade section that spins on the bottom of the broken jug . Thank you, regards Bronwyn
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
Mar 02, 2015 | KitchenAid KSB560 5 Speed Blender
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
Sep 07, 2012 | Oster Blenders
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
Aug 26, 2009 | Blenders
May 24, 2009 | KitchenAid KSB560WH 5-Speed Blender
Jan 11, 2009 | Blenders
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
1,764 people viewed this question
