Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
Posted by happynown4ev on
Anonymous
  • 26 Answers
Use straight 140w G-4 gear oil. Oriely Auto parts carry it in one gallon jugs for $12.00. NAPA auto parts stores can order it also but it is more expensive.
Frank
Posted on Sep 14, 2009
Anonymous
  • 22 Answers
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Posted on Jun 14, 2009
What type of oil does a troy built tiller use? I have lost my book.
This is dependent upon what the engine application on the tiller is. If it's 2-stroke, use a quality synthetic or semi-synthetic 2-stroke oil mixed with the gas. If it has a 4 stroke engine use SAE30 oil, unless you run synthetic (which I highly recommend), then you can use a multi-viscosity oil if you like, say 10W-30.
May 24, 2011 | Troy-Bilt Pony Garden Tiller
Troy Built Tiller - How much oil does it take?
About a quart ... but dont overfill. There is a dip stick on the engine.
Aug 03, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Tiller will not engage tines
Is this a two speed or a 4 speed ... it is a MTD built Troy or a Troy built Troy or do you know?
There were two versions of Horse built in Troy, New York bu Gardenway ... the two speed and the 4 speed. The two speed used two belts the same size while the 4 speed used one belt on different sized pulleys. There was also a variation that used a slip gear ... this model was built to accomodate other accesories ... log splitter and generator.
If yours is a Troy Built from Garden Way, I can help you. If this one is from MTD, I'm not so sure. Can you ID your machine for me please?
Jun 13, 2010 | Garden
Owners namules
http://manuals.mtdproducts.com/mtd/Public.do
Go to this website and type in Horse for your model number.Just put thenumber 1 in for your serial number and it will bring up several horse tiller manuals. If yours is a 1976 then it should be
a Horse I model. This should be a two speed tiller and have two drive belts.
Frank
Jun 01, 2010 | Troy-Bilt Pony Garden Tiller
What kind of oil do you put in the gearbox of a 15 year old pony tiller
Hello. The older models use SAE 90 or SAE 140 weight gear oil. joe
please rate my answer as very helpful. Thanks. Joe
Apr 25, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Free wheel
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Apr 19, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
361 people viewed this question
Top Troy Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Troy Garden Expert? Answer questions, earn points and help others
