Fujifilm Finepix T400 Logo
A
Anonymous Posted on Feb 06, 2014
Will not switch on even when plugged into mains
Philips TV freezes or turns on/off continuously
please check on mains chord and plug or even better the plug itself by connecting another lamp to see it flickers meaning something wrong with the AC line in.
1.either replace mains power chord
2. also see solder connections inside TV that is if you know something about mains take care to switch of mains and disconnecting main chord
happy hunting
Colour tv does not switch ON. Pilot led always on.
Main board fault. Contact any service technician. In most cases, a firmware update might be necessary after the main board replacement, and it is a skilled work. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Surf the site with patience.
2answers
Why wont my 1989 honda civic start ? i replaced the starter and battery, wont start, not even off a jump start, but will off a push start get a dull thud sound from the main relay, could it be bad ?
Your Civic has a manual tranny - correct? The problem could be a bad Clutch Safety switch. Many Hondas are listed as having this switch with the manual tranny. The switch prevents the car from starting if the tranny is in gear and the clutch is not depressed, preventing the car from lunging forward. If the switch is there , it is located on the clutch pedal bracket. The switch has two wires, so if you remove the electrical plug from the switch and jump the plug, maybe the car will start? Good Luck!!!
2answers
When I switch on the On/Off button the machine trips the mains electricity. It is a Hoover Performa 1100 Washing Machine
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
My notebook will not switch on even when plugged into the mains although I think that the mains feed is a bit dodgy too. It worked perfectly last night before I switched it off and plugged it in to...
Hi!
Please remove the battery and power cord from the laptop then wait for 60 secs. and connect the power cord only and try to power on if the laptop do not power on then either dc jack or the power circuit board is defective.
Packard Bell Laptop goes flat even when plugged into the mains su
Are you sure that the power adaptor is working? Does it have any light on the adapter box that informs about it's operation?
What usually happens is that the cable going from the adapter to the laptop gets crackled from repetitive bending, either at the plug, or at the box inlet. Inspect if the cable is intact, and if possible, checks if there's a required DC voltage on the plug.
Perhaps you might need a new adapter for your laptop.
Mains switch on
some shortage inside the computer, go for technical assistace from qualified technician
Ds lite console keeps switching of then won't start again
Theres an internal error you will need to get it sent off for repair
TomTom will not switch on even when it is plugged into the mains power
yes just press the reset button under the tomtom you can find this next to all the pins where your tomtom dock goes in.
Toshiba e-studio 35 Copier Problem
there is one more swith to off the machine.the switch which you are using is only for make the machine into energy saver mode.in that mode machine will be warmed up to take the printouts from computer.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
