The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head.
Here are some steps you can try to troubleshoot and fix the issue:
Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
If the error persists after trying the above steps, you may need to replace the print head.
If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
The Epson printer error Code 0xf1 is due to a corrupt registry entry on your PC (Computer). When this error occurred, then the print head is not able to move.
Troubleshooting methods to fix Epson Printer error code 0xf1
·Reset the printer settings ·Set Epson printer as a default one ·Update Epson printer drivers ·Clear paper jam
The Epson Printer Light blinking error can be caused due to printer print head is overheated, low or empty ink tank, printer fuser not working and more. Follow the simple steps to fix Epson printer lights blinking error:
·Check printer ink cartridges ·Fix paper jammed ·Check printer print head and fuser
General error : head carriage error / chip not recognized. Head carriage can't move freely. Just turn off for about 1 hour, turn on again without ink tank. Plug ink tank.
