V
Vicki Dubs Posted on Feb 06, 2014
How many GB memory card will it work with? I have a 8 GB and it wont read. What size caed does it go up to.
Version 3.101.151
1helpful
2answers
Camera saying memory full but card brand new
Not only the size is important, the manual says SD max 2 GB.
But even a 1GB SDHC card won't work, because the camera is not compatible with SDHC and SDXC.
They used to make SD cards up to 4 GB, but most new cards from 1 GB and up are SDHC and above 32 GB the cards are SDXC. Older camera's can't handle these cards, although they look the same.
To read more and to understand compatibility from device versus Memory card, read this:
Secure Digital Wikipedia the free encyclopedia
How do i insert the 8b memory card in the memory card reader? i've tried it several ways and it does not light up??? i need a visual
The Dynex 5-in-1 Reader may be too old to read high capacity secure digital cards. (HCSD)
An 8 GB SD card is definitely going to be high capacity. Only the relatively newer SD readers can read the HCSDs.
Try putting in a 2 GB or lower size SD card and see if it works. If it does, then your card reader doesn't support higher capacity cards.
Good luck and thanks for using FixYa.
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
I have a Sony digital camera model # DSC S75. I would like the largest memory stick available for still photos. I get confused with GM and MB. I found one for 32 GB, is that the lrgest and about how much...
I did a bit of research on this, and you're going to have to be very careful. Your camera is only compatible with the very first generation of "memory stick". That sounds like a generic term, but it's actually a Sony specification. Please take a look at the wikipedia page on memory stick, and note all the newer versions. Also note that the 'memory stick' is no longer manufactured. Here is a list of memory sizes, I agree that the Mb and Gb are confusing. Each one is double the size of the one before.
8 Mb
16 Mb
32 Mb
64 Mb
128 Mb
256 Mb
512 Mb
1 Gb
2 Gb
4 Gb
8 Gb
16 Gb
32 Gb
64 Gb
Now, you will have to find a genuine Sony "memory stick" and not the Pro, or Duo, or anything like that. When they were manufactured, the largest one was 128 Mb, so that is the limit for your camera. Anything in "Gb" or Gigabytes cannot be a memory stick. I did find 128Mb memory sticks on Amazon. The review page on DPreview will tell you how many pictures you can store on a card half the size, just double it.
6helpful
HP Photosmart C5180 cannot read the sd memory card
If the memory card size is more than 2 GB, you would face issues, these printers support the cards maximum of 2 GB, only new printers like Photo-smart Premium C309a support 8 GB cards,
Memory cards wont format, says card is full
Is the write protection enabled on the cards?
Which size having the cards?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
Blackberry Flip won't read memory card anymore
Make sure you have the right sized media card for your device OS:
BlackBerry Device Software 4.2.0 Up to 2 GB BlackBerry Device Software 4.2.1 Up to 4 GB BlackBerry Device Software 4.2.2 Up to 4 GB BlackBerry Device Software 4.3.0 Up to 8 GB BlackBerry Device Software 4.5.0 Up to 8 GB BlackBerry Device Software 4.5.0.81 and later Up to 16 GB BlackBerry Device Software 4.6.0 and later Up to 32 GB
http://supportforums.blackberry.com/rim/board/message?board.id=8300&message.id=18217&query.id=64220#M18217
Kodac easy share c330 says memory card full, but it is a new card
Which size has the memory card? More than 1GB?
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Can I upgrade the 8 GB SD card to a 16 GB SD card?
You should be able to use any size SD card you want to.
4answers
Memory card
i believe they are only capable of 2 gig, get a brand new 2 gig for around $7 online, and the device should recognize it, i have the brand name kingston, my problem now is, i cant sync music, if u figure that out, let me know
Top iLO Audio Players & Recorders Experts
Marvin
Marvin
SmartAviator
SmartAviator
k24674
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
