Question about Hobart HL600 Legacy Stand Mixer
The Hobart HL200 out of order and on screen appear the code OPL
2 Related Answers
Anonymous
SOURCE: HOBART HL200 error code oc3.
For $9.95....I'll tell you
Posted on Dec 11, 2008
aviral_srms
Aviral Saxena
  • 1216 Answers
SOURCE: MY Hobart Hl200 is working
Could be that a gear is missing (broken) on the shaft that works the 2nd and 4th gear.Check that the gear on the shaft that the clutch gear engages with does not have a sheared key. if u find the broken part you may yout replace them to work fine.
if u have mechanical aptitude u can do it easily.
although below link does not contain your product model , u can still take help if u have problems
http://www.food-equipment.com/parts_Hobart_mixers.htm
Posted on Mar 16, 2010
Why is oil leaking down into the mixing bowl on the Hobart HL200 Mixer
There is a leaking gasket. The OIL is from the Grease applied to the gears. It may have somewhat turned a portion of lube to a liquid state due to heat within the motor housing during use. The OIL as you put it, could also leak out from the port where you insert the beaters. If so there is also a set of seals to prevent that from happening, and if they are worn or damaged, leaking can occur. This unit needs a professional serviceman to fix the problem.
Feb 03, 2015 | Hobart HL200-1STD Mixer
MY Hobart Hl200 is working with only 2 speeds when it used to work with 4 speeds.
hello! the speed select switch is defective...It is located behind the timer control board...Part # is...00-874831
Guru.............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Mar 16, 2010 | Hobart HL200C Mixer
I need a parts manual for hobart legacy hl 2oo mixer. Start button dose not work need a new one!!!
www.hobartservice.com.
Enter your machine ML number in the smart parts window. It will give you exploded diagrams with part numbers.
Aug 15, 2009 | Hobart HL200-1STD Mixer
Hobart Legacy HL120
I haven't ever worked on these units. But from looking at the parts catalog, (pg 4) and considering your failure, I would suspect you have a bad speed control. And being that it is a potentiometer, it's pretty likely to be the cause. (Item #1)
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/0420EE614011415A85256FE2004E0FFA/$File/F43101%20Rev%20A_lk.pdf
I would ask Hobart, but I doubt any special tools would be required. (NO splicing, crimping, or soldering)
I hope this helps - Mike
May 03, 2008 | Hobart HL200-1STD Mixer
Drive settings for Hobart Legacy HL-200
That software is proprietary. The only way to get a properly functioning drive is to order one from Hobart. www.hobartservice.com
Apr 21, 2008 | Hobart HL200-1STD Mixer
Hobart HL600 Legacy Stand Mixer Logo
44 people viewed this question
Top Hobart Food Mixers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Lawrence Oravetz
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
