RCA L32HD31 32 in. LCD HDTV Logo
Posted on Jun 06, 2009
I have the RCA model L32HD31R LCD TV and I need the 5 digit code for the Comcast DVR remote with the red OK button
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2547
Points
7
I have a RCA model L32HD31R LCD, also but the codes from comcast will not turn tv on or off.
  • Bettye Sclater
    Bettye Sclater Dec 28, 2013
    What's the solution. I don't see it?
How do I program a universal remote to an RCA Model L32HD31R
This is the general setup proceedings to a universal remote control.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the dropdown list by the 'Sidebar' of the display window. It will make search easy.
2answers
I need a 5 digit code for my Rca L32HD31R LCD tv to connect to comcast. Any help would be appreciated.
Hello
Five digit codes to check with RCA tv with comcast remote control are:
11447, 10047, 10090, 10679, 11047, 11147, 11247, 11347,
3helpful
3answers
I can't program my Comcast remote for my Olevia model 232 S12, I have used all the codes comcast suggested to no avail
The Comcast remote will unlikely have Olevia codes available since its design age is much older than the set's. In addition, it may never have them since Olevia is bankrupt and probably of little interest to Comcast. You might check Comcast's website since the most recent codes will be available there.
6helpful
3answers
Need remote code for Comcast remote to L32HD31R RCA.
I finally found an RCA Universal Remote model RCRN04GR 4 in 1 that works with this TV and easy to set up.
4helpful
Comcast Remote Codes for a RCA L32HD31R LCD TV Also Panasonic
Hi Attychase,
Comcast actually has several different remotes for their different set-top boxes and the remote codes aren't always the same. They list all of their current remote devices on the following page. If you click on view manual it will give you a list of remote codes.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Hope this helps.
1helpful
Need to program remote, don't have codes
RCA TV/VCR Combo Model T09085:
Comcast Digital Adapter Remote (DTA) Code is... 00000
Comcast Universal Remote - Red OK/Select Button (DTC)
Code is... 21479. This code controls TV On/Off and VCR All functions. I could'n find code for vol+/vol- and mute.
5helpful
Remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
25helpful
8answers
Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
1helpful
3answers
Olevia t.v.
try rca, lg, philips, yamaha these are compatible with olevia
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
